2007 Jaguar XK
2007 Jaguar XK
Hi my name is Alex I have a 2007 Jaguar XK with only 51000 miles on it the other day seats and windows don’t work at all check all of the fuses one by one the one by the engine the ones by the driver side foot wall and the ones behind the rear seat all were good as well as the relay don’t know what else can I check but the module are not burn because when I sent power with the scanner everything works perfectly so can someone please tell me if they have this issue before thanks
Are you able to start your car? What happens when you try to start the car? What, if any, kind of readings are you getting from the various dials, infotainment system and controls? The reason for the above questions; is it sounds like you have a bad battery from the limited information that you provided. Your battery should give a reading of 12.6 volts with the car at rest and turned off. If you are going to buy a new battery make sure it is fully charged before it is installed in your cat. Also acquire a battery tender like a CTek or similar and use it when your Cat is a sleep.
Gunit, I live in Richmond, if you want to drive over here, I'll be happy to look it over. If I can't find the problem, I have a good friend who is the chief tech at a local Jaguar dealer who will look at it during off hours. I have had him do a number of things for me and he has always been very reasonable.
Gunit (08-11-2020)
2007 Jaguar XK
2007 Jaguar XK
I just spend $200 on a new battery thinking that it will solve my problem with the vehicle and still the same seats and windows are not working at all DONT know what to to next but like I said before if I shoot power with the scanner everything works perfect so I know the modules have to be good cause is a comunication between the scanner and the modules right???
What scanner are you using? I’m not familiar with controlling the modules individually via a scan tool (even SDD), but I am more familiar with X100.
That said, I installed a new battery and still had drain and intermittent issues. Replaced the new Megatron with I think a Bosch (returner the Megatron) and all my issues with seats and steering wheel not moving were resolved.
2007 Jaguar XK
[QUOTE=dsd;2273892]What scanner are you using? I’m not familiar with controlling the modules individually via a scan tool (even SDD), but I am more familiar with X100.
Hi Iam using a snap-on scanner that I just purchased for my bodyshop and like I said when I plug it to the car I can move the seats back and forward and I can even put my windows up and down so that tells me that the modules are not burns or bad if it does all of the moves with the scanner
