2007 Jaguar XK convertible broken antenna
Got home last week. My rear antenna was hanging off the car by only the mast and cable. The cable was detached from the power unit and there was no bezel or aerial sealing grommet. I ordered a new power unit JLM21920. The mechanic said i needed the sealing grommet or "cap" I think the part number is C2P11987XXX. I cannot find this part anywhere as it is discontinued. Any ideas on how to fix this problem if I can find the sealing grommet? I called welsh Jag and they dont have the part. I also contacted Jaguar Heaven in Calif. but havent heard back yet.
Received 2,011 Likes
You could also try Pacific Motors in Michigan for the missing parts.
After Ford bought Jaguar in 1999, it replaced virtually all of the Lucas electrical components with Ford components. For example, the glow-in-the-dark plastic emergency trunk release handle in my 2009 XKR Portfolio convertible was made by Ford. I replaced it after it broke.
I suspect that the radio antenna and related parts came from Ford. Search Ebay for radio antennas used in Ford vehicles from 1997 - 2007. There may be several different designs, so compare the photos to what was on your car.
If you can't find the exact part, maybe this will work.
31" Black Stainless Antenna Power Mast AM/FM for FORD RANGER 1983-2011
Good luck!
Good luck!
CurtJ (01-11-2024)
Think there is also a thread that lists places to check for replacement parts both new and used. Just recalled that there’s a place in Texas called NOMA, that has been recently placing parts on eBay.
kj07xk (01-11-2024)
ptjetpilot
05-11-2017 01:27 AM
