2007 Jaguar XK dashboard went blank and car won't start
Nearly EVERY electrical problem with these cars is battery related. Can/did you check the battery voltage? It should be 12.6 or so to have close to a good battery. If not, why did the battery go flat? Merely an old and worn out battery? Check the date on it. Also, bring the battery to an Auto Parts store, most do a battery check for free, but usually you'll need to put it on a charger for 24 hours beforehand. Not a "maintainer" or "trickle charger", but an actual battery charger.
If your battery checks good, then there is probably a problem with the alternator/charging system.
rlentini
05-31-2017 08:15 AM
andrew2110
04-23-2016 07:14 AM
rdr
02-19-2011 10:25 PM
