2007 Jaguar XK Replacement Antenna
The many sponsors here can quote you a price. Many folks on the forum just disconnect or use a marine antenna wrapped around the interior of the boot.
If you still want the mast that moves up and down as the OEM does, but don't want to pay the price, I've read the Mazda Miata 1999 - 2005 retractable antenna is a good fit.
If you try using "search" you may find a good tutorial on the antenna delete. Basically it does away with the periscope and you then use a wire boat antenna that goes into the trunk lid. Parts ran me @$40 took maybe 2-3 hours to do no cutting or drilling or anything like that.
The good - I retained the same FM reception previously enjoyed. Looked a LOT better. Low cost. Nothing shows visibly
The bad - some say good... you lose AM reception completely but that was never an issue as I never listened to AM anyway
Before doing anything further, can you tell us the problem with the antenna? Is it that it will not retract fully? Or extend fully? If that is the issue then please note: in most cases there is nothing at all wrong with the antenna or motor. What does happen is that dirt and corrosion interfere with full retraction or extension, a problem very easily rectified with 5 minutes work, some wd40 and a bit of metal polish. In severe cases the dirt and corrosion are so bad that the motor cannot overcome the friction: result: the nylon cord breaks.
Barring the last scenario (breakage), the solution is to extend the antenna fully - and in some cases this means helping it manually as the antenna motor is working to raise it. Once it is fully extended, use wd40 or similar to clean all the dirt at the segment joints. Once this is done, polish the entire antenna mast with metal polish (upward strokes near the segment joints so that you do not force polish into those areas)...,there put some silicone spray on a cloth and liberally wipe UP the antenna shaft. If the antenna is bent then it can be gently persuaded back into shape befor the cleaning process begins.
It has taken longer to describe the process than it takes to actually do it! Now the antenna unit is good for another decade. The units can and do last years and years if cleaned and lubricated occasionally. I have brought numerous aerial units back to perfect functioning this way.
And I think the.electric antennas are neat.
kj07xk (05-03-2017)
Received 2,012 Likes
If the problem is the mast, i.e. its broken, you can replace it with one for the XK8, as they are apparently the same. See this thread:
https://www.jaguarforums.com/forum/x...lacement-8478/
You can get a replacement mast for $15 - $20, and apparently the replacement task only takes ~15 minutes.
EDIT: I just ordered the one mentioned near the end of the above thread, thought it would be useful to have as a spare, while they're available. Found it on Amazon for $19.99:
https://www.amazon.com/AntennaMastsR.../dp/B00JFGV9S2
You nailed it.
2007 Antenna problems
Purchased a 2007 Jaguar.....Antenna just popped out of the mast and dragged the ground for some time before a considerate driver signaled me that there was some attention needed to the rear of my car....LOL. The antenna mast is easy enough to replace. you can get one on ebay for less then $20.00 Do not pull the whole antenna mast Assy. from the car, as I did....it's not necessary to replace the mast....My problem now is that.... there was NO antenna retaining nut screwed onto the top of the antenna mast to begin with......and you can't buy one. Has anyone purchased a full antenna mast from Jaguar or aftermarket.....if so you will have an extra antenna Mast retaining nut I would be happy to purchase from you.....or does anyone know of a place where one can be purchased ....Thank You
I think its two pieces....I've tried junkyards....seems no one at a junkyard is going to look for a retaining nut on an antenna. have located an 07 jag in a bone yard....I called twice yesterday.....said they would look but I haven't heard back from them....Not going to hold my breath on getting a return call....LOL
Welcome to the forum LadyVee,
I see you posted this question eight days ago, logged off the forum six minutes later and haven't been back since.
If you do return, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
The following 2 users liked this post by GGG:
Sean W (08-26-2017),
winstonsalemncxk (08-14-2017)
The following 2 users liked this post by sov211:
if you need adapter 4 aftermarket .this one fits .. Metra 40-EU10 Antenna to Radio Adapter Cable for Select 2002-Up BMW/Volkswagen. every websites in the world will say it will not fit..20 dollars cheaper ...jaguar 25 dollars ....vw price 5
