2007 Top won't go down
Old 02-12-2016, 02:13 PM
robbing's Avatar
Default 2007 Top won't go down
2007 XK
My son fell asleep at his soccer tourney last week with the car off but the a/c was blowing on him. Ran the batt down so we had to jump it. Now the top won't go down. I keep getting the "luggage cover isn't in place" message but it is in place. I didn't get an owners manual with this car so I can't turn to that. Any help?
Thanks in advance.
Old 02-12-2016, 02:41 PM
kj07xk's Avatar
Received 2,048 Likes on 1,372 Posts
That luggage cover is a tricky thing.
Try taking it out and the putting it back in again, making sure to fully deploy it (I just bumped mine once when putting something into the trunk, and that dang message came up and the top wouldn't open).
Old 02-12-2016, 04:00 PM
robbing's Avatar
I know it's properly seated. I've taken it out and put it back in at least 6 times. I can see where it fits and it's perfectly in the spot.
Old 02-12-2016, 04:32 PM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
I'm guessing here that you jump started it by removing the cover and the battery cover to get at the battery. If so then when you put it back together you either have the cover in wrong or you damaged the switch. Re-check your work. If you did not touch the cover and used the jump points in the rear left side of the boot then you have a switch failure.
Old 02-12-2016, 04:48 PM
Stuart S's Avatar
Received 6,391 Likes on 3,501 Posts
Or maybe it needs to be manually lowered using the special wrench located in the fuse box in between the rear seats in order to reset the system. I think there's a thread on this. I'm on my cell and can't search for it.
Old 02-12-2016, 05:55 PM
tommytess's Avatar
When this happens you need to keep your finger on the button for at least 30 seconds to get it to retract again.Also reset the windows using the globle positioning on the key fob.This worked for mine after a battery change.
Tommy.
Old 02-15-2016, 08:46 AM
robbing's Avatar
Tommy.
How do you do the global positioning on the key fob? I know sure the luggage cover is seated correctly. I have no clue where the switch is so maybe I did damage it?
Old 02-15-2016, 08:50 AM
WhiteXKR's Avatar
Received 2,989 Likes on 2,125 Posts
Is the luggage cover not just seated properly, but also deployed? Also, your boot must be shut for the top to operate.
Old 02-15-2016, 08:52 AM
tommytess's Avatar
Unlock the car keep the unlock button pressed down and the windows will open.To close them keep the lock button pressed down and windows will close They should both open and close in the same position.
Tommy.
Old 02-15-2016, 08:57 AM
robbing's Avatar
Thanks Tommy. I just realized in my original post I didn't say everything going on. The two back small windows both go down and then the process stops. I'll try the key process and also manually lowering the top. I HATE not having an owners manual.
Old 02-15-2016, 09:00 AM
WhiteXKR's Avatar
If you have the 'luggage cover is not in place' message, nothing else you do will get the top to move until that is resolved. I do not recommend manually operating the top under these circumstances...it will just complicate the situation.
You can also download the manual for free from http://topix.landrover.jlrext.com/to...cle/lookupForm
Old 02-15-2016, 11:16 AM
robbing's Avatar
Are there any metal pieces on the connections of the luggage separator? I see where there are two metal "post" so to speak on the car itself where the separator sits but nothing metal on the separator itself. I just found a little metal clip laying in my trunk and I have no clue where it came from.
Old 02-15-2016, 11:21 AM
WhiteXKR's Avatar
Just metal springs. The sensor is magnetic that detects when the separator shade is in the full open position. The sensor is built into the left side bracket.
Old 02-16-2016, 08:22 AM
robbing's Avatar
I'm at a loss. I know it's seated correctly. I can see that it's flush across the bottom of where the separator sits. I guess I'm going to have to find someone to check it out.
Any recommendations in the DFW area?
Old 02-16-2016, 08:54 AM
kj07xk's Avatar
Ok, it's seated correctly.
Is it fully deployed and locked in place with the tongue pointed up?
And the trunk is fully closed?
Bummer if that's all true.
Hope you get it fixed easily.
Old 02-16-2016, 10:41 AM
tommytess's Avatar
Do you have any warnings on the instrument cluster.?.
Tommy.
Old 02-16-2016, 12:11 PM
Cee Jay's Avatar
Received 5,511 Likes on 3,242 Posts
If you REALLY want to go to a dealer, I got my XKR from Park Place Jaguar, 5300 Lemmon Ave. Dallas. Nice people, never had a complaint.
However, any reputable independent repair shop should be able to find the problem.
Old 02-16-2016, 03:50 PM
sov211's Avatar
Received 2,288 Likes on 1,382 Posts
Default Ockam's razor
No one has yet mentioned the obvious: the problem started with the battery being run down. Low voltage in the XK results in random electronic issues, and yes, that does include the operation and latching of the convertible top. Job 1 here is to ensure that the battery is putting out full voltage - full voltage.
Virtually all complaints regarding electrical components on the XK are solved by simply ensuring a constant full voltage supply.
Old 02-16-2016, 04:51 PM
robbing's Avatar
Tommy.
No warnings. Just says the luggage thing isn't in properly.
Old 02-16-2016, 04:52 PM
robbing's Avatar
The battery was run down and I actually had to take it in to get it charged. I will check the voltage this evening. What voltage should I be getting if it's good?
Quick Reply: 2007 Top won't go down
