2007 x150 XKR Badge
2007 x150 XKR Badge
After some cockwomble stole my front growler badge I am struggling to source a replacement, anyone have the part number or a good source? The pin layout is different to even very similar year badges. The dual pins are in a vertical layout not horizontal like most of the badges.
https://www.growlerparts.com/xk8-and-xk
When this happened to me, I had to get both the growler emblem, and the mounting bezel, which are 2 separate parts. C2P4892 and C2P1594. The growler comes with double sided sticky to mount into the bezel, which bolts to the grille. You have to remove the bumper cover to bolt the assembly back on.
Deabs (01-19-2023)
needs?
I had to get creative with bolting it back on. I believe that the correct hardware for attaching it is a stamped sheet metal 'nut' that fits around the smooth posts. As I had neither the nuts or any idea of what I needed, I used the hole in the center of those posts to put a screw in, and a stack of tiny washers to take up the space between the screw head and the grille. Sorry, no pics as I'd have to pull the bumper cover off. In hindsight, I'd take that little plastic bezel/plinth/whatchamacallit to the parts house and find 2 stamped sheet metal nuts that will fit, as that would be the less complicated solution.
Sometimes I fix things with what I have on hand.
Similar retainer "speed" nuts are used on the 20" Selena wheels that were original equipment on my 2009 XKR Portfolio. Those wheels feature chrome overlays that fit on the middle spokes. Each overlay has two posts that go through the spoke and is secured with two of these retainer nuts:
Here's the Selena wheel. Enlarge it to see the overlays.
ExKayRick (01-25-2023)
Replacement of Jaguar emblem on grill
The ornament badge C2P1594 didn't fill the space on my grill and the two posts on the back didn't align with the holes on my grill:
So I ordered emblem C2P4892 too. The chrome ring around the face of the bracket fills up the space on my grill nicely and the posts line up correctly. It even comes with the plate and nuts to secure it. This is what the two parts look like together:
McJag222 (01-24-2023)
