2007 XK 4.2 Timing Chain???
2007 XK 4.2 Timing Chain??? **Panic Over**
That’s a £1 coin for scale (23m diameter)
Found this mangled metal on the drive, and when I started the engine there was a rattle so stopped immediately.
Looks like some kind of guide or bracket. It is stamped “K20” and has “Adamo” in a script font. I have googled and can’t find any definitive part.
I suspect it is associated with the timing chain but can anyone confirm before I book a recovery truck?
That’s a £1 coin for scale (23mm in diameter) Looks like I may need a few more of these!
The timing chain is entirely inside so for that to be associated with it there would need to be a big hole in the block or somewhere!
Having started the engine there would be MASSES of oil everywhere - which I feel you would have mentioned so don't have.
See if someone knows what it actually is.
Chris77 (10-01-2021)
Thanks all for your feedback!
I checked under the bonnet today… no outward sights of the cause of the noise
I decided to try starting it, no sign of any rattle the engine… only a sweet V8 burble.
Not sure what I heard last night….. maybe some leaves got blown up into the engine bay in the high winds. A definite case of paranoia… (not had it long and loving every opportunity to drive it)
