2007 XK air filter replacement
I researched this a year back(actually called K&N) and at that time they did not make a filter for the 07-09 model XK.
What number did you get?
Vince
joel97 (11-09-2013)
The following 2 users liked this post by joel97:
CleverName (11-09-2013),
hawaii (11-09-2013)
tip of the day=When your cleaning or using the k&n for the first time-just put a fine, light mist of the oil on the filter. Just one pass of the spray. Alot of people spray a ton of the oil on the filter & the oil ends up getting into & destroying the MAF sensor=$$$$$.
However: K&N's Response to this urban myth
hawaii (11-09-2013)
Joel,
I've attached a coupe of relevant diagrams from the Workshop Manual.
First one is the overview of the system: the air filter assembly is #6
The second picture is looking up inside the LH wheel arch.
I found it easiest to remove the wheel. There are about 10 or 12 Torx bolts to remove, and a couple of crosshead screws too, then gently pull the liner out of the way. Then 1 or 2 screws on the filter box, and a 'tray' with the element in it wll slide out.
Yeah, its a pain - and the XK-R has one on each side.....
Jeremy
Jeremy
hawaii (11-09-2013)
Series1fan
09-05-2015 08:02 AM
