2007 XK battery drain
Bill Mack (11-05-2020)
I started closing the trunk on the cord then kept forgetting it was still plugged in.
Ran the ctek over like 3 times but its still holding up!
I leave a little rag there so the trunk isn't fully closed - and the dash reminds me the trunk is open and ctek plugged in BEFORE i back out.
I like jagtoes solution but theres still nothing to remind you its plugged in!
CanadaCat, ouch! Mine is mounted on the wall of the garage, so dropping or running over the unit itself is not an issue. But I am sure I would do fatal damage if I just backed out of the garage with the unit still attached to the battery. Thus the 4x6 card in the instrument binnacle, as I previously posted here.
Bill Mack (11-06-2020)
My excuse is I only drive this one once every month or two...
#30
#33
I soldered on a quick-release 12VDC connector so I didn't have to worry about pulling stuff apart. I also made the cord a lot longer at the same time.
Bill Mack (11-08-2020)
#34
Just registered and this is my first post here. Be kind lol.
I don't yet own an XKR but I am currently looking to buy one. Forgive my ignorance but why does the battery drain so quickly and need to have a trickle charger attached? I've had cars that have sat undriven for a few weeks (was away on vacation) and they started right up with no issues. I'm seeing this as an issue and have just wondered why.
Thanks.
Thanks.
#35
There’s lots of memory that needs to be kept current, coupled with an alternator that just barely keeps up (weight/size and the accounting dept strike here), a performance engine that requires a good jolt to start on top of lots of these are “sunny sunday” rides and you have a recipe for routine battery failure. My Expedition is on it’s second battery in 4 years and 20k miles (sound familiar??) and is also kept on a tender, just like it’s tea drinking cousin.
At least that’s my thoughts. I’ve found over the last 23 years that keeping a battery on a tender will usually almost double a battery’s life compared to not being on a tender. And that’s on older vehicles that have no memory requirements. No computers, no radio, no nothing. The battery truly only starts it.
#36
Im with the new guy. Battery should not drain in a week or two weeks or a month maybe three months or five months but not a month. I have an 06 STR And I don’t keep it on a battery tender and the batteries been in it for years. and my car is pretty loaded. But ive never had an issue. Soooooo maybe it doesn’t affect the STR?
Or maybe I just never left it undriven long enough? I don’t know
#37
Thanks.
Thanks.
I have had my '10 XKR for 3 years and only use one when I am doing something that will drain the battery and also had no issues for 4 years once I changed the battery on my '07 XKR. Before that I was plagued with issues.
My one concession is to lock the car whenever I am not using it as that makes it shut the computers and various accessories down a lot quicker.
#38
#39
I bought my XK 4.2 N/A a couple of months ago from a private seller who had owned the car only briefly and driven it rarely. He did not know the age or condition of the battery, but it would not start the car during my pre-purchase inspection and had to be jumped. I quickly bought a CTEK battery maintainer after reading posts on this forum about battery problems, and kept the car on it at all times it was not moving. With this regimen, the battery seemed OK. But a couple of weeks later, I had the car in the driveway to install the Cambo/Old Jaguars Bluetooth streaming unit, and had one or both doors open for a couple of hours. When I tried to start it, no go. I bought a new battery immediately.
However, I had gotten into the habit of keeping the car on the CTEK and decided, even with the new battery, not to take any chances. Maybe I don't need it, since I drive the car at least once a week and have the new battery. But it's no inconvenience to keep it on the maintainer, and stuff happens...
Aarcuda (11-12-2020)
