2007 xk battery tray
The battery needs to be replaced in my 2007 xk convertible. The old battery leaked all over the battery tray and the sheet metal underneath it, and there is significant corrosion. I would like to remove the tray so I can do a complete clean-up job. It seems to be riveted in place. Is that the case? Should I just leave the tray in place and clean up the best I can?
Stuart, thanks for the tip about venting. The vent hose was attached when I removed the old battery, but I'll check and make sure the hose isn't kinked or plugged. Now I'm wondering if that had anything to do with the extensive corrosion on and around the battery tray.
The PO's of my poor car kept the rear panel off and a 15 amp charger hooked up all the time versus just replace the battery... Looked like old soda had been poured across the top from it overflowing when overcharged.
With the new battery and occasional topping off with a tender the battery stays new looking. I sprayed LPS3 on the corroded bits to keep them from getting worse.
Sean W (08-20-2018)
Thanks to all for the insights and histories. I got a new battery at a pretty decent price ($130) but it was coated with dust and looked like it had been sitting for a long time. It has a label on it which could be the date code (31/16) from the manufacturer in Germany. I hope that doesn't mean it was made during the 31st week on 2016. But if it doesn't hold up, at least is has a 36 month full replacement warranty. I guess I'd be willing to go thru the hassle of replacing it again if it failed within that time. I will maintain it as necessary, with an onboard Schumacher 1.5 amp charger.
FS[MidWest]: Parting Out 1997 XK8 Red Conv II
CyJag
38
04-23-2017 10:58 PM
