2007 xk convertible
Until you know otherwise I would trust the sensor and shut the engine off ASAP. The fan running after the engine is shut off is another indication of a problem.
First check your coolant level. If it is low look for any evidence of leakage. If the coolant level is OK get an IR thermometer, they are cheap at Harbor Freight, and use it to check the coolant temperature. If the coolant level is OK and the temperature is high I would check the radiator for blockage and then change the thermostat.
There is a just a warning light that comes on to warn you that your engine is about to die.
Therre are several threads on adding gauge options. This is what I have:
https://www.jaguarforums.com/forum/x...option-181348/
Rogerj (07-29-2017)
If the fan stays running post engine shut down the engine is excessively hot and need immediate attention. Historically, on an XK it's the T-stat housing fails jamming the T-stat or chunks fall into the water pump or the T-stat's rubber cover delaminates causing it to stick. The housing and T stat replacement isn't terribly difficult or expensive. The water pump is a little more difficult but easier once the housing is out of the way.
Either way it must be addressed or you will not be running it for long.
Rogerj (07-29-2017)
It looks like you are going to play a high stakes gamble here. My suggestion would be to not run the car until you get the gauge on it and then if it starts be prepared to shut it down if the WT goes over 210* F. If it starts to exceed that then you either need to start tearing things apart or flat bed it to someone who can find/fix it.
The coolant water temperature can safely go over 210*F. Both my XK and XJ routinely go over that. The thermostat is not fully open until it gets to 205*F. On hot days in Tucson [115*F] my XK will get to ~223*F when sitting at a stoplight. Others have reported similar temperatures. Jaguar turns on the idiot warning indicator at 245*F. The coolant should boil at about 255*F so the idiot indicator gives a little margin.
I set my warning to go off at 225*F.
I agree that you should not run the car until you fix the cooling problem.
Bottom line, if the idiot light is illuminating he has a problem that needs to be fixed before driving the car.
