2007 XK Convertible Electrical issues
Hi, I just purchased a 2007 XK Convertible. The car was a fresh water flood but I don't know how far the water got into the car. It got into the engine but I had the water drained and the car runs fine. For some reason, the seats don't move and the radio has no sound. I checked all the fuses but I couldn't figure out the relays because it doesn't list them in the owners manual. Also the air bag light will not go out. Any suggestions?
Probably, I've been considering to take my seats out but I have no idea on how to reach the back bolts because when I got the car, the seats were fully reclined back and slid back all the way is its nearly impossible to reach the bolts. And I also suppose that the radio AMP is under the seat also because it will not stop blowing the same fuse for the radio.
Looking at my service manual, you have a seat module for each seat. The seat module is under each seat. I'm afraid to say that your car was a lot further under water than you were told. The amp is there right behind the screen on the heater box. It shows some other modules associated with the entertainment system and they seem to be in the same area. Did you check the aux fuse/junction box between the rear seats?
XKR-S (09-12-2011)
Man I hope you got a great deal, I recall a similar post on the Corvette Forum a few years ago and it ended up costing the buyer more than had he just purchased a similar "non-water" damaged car. He eventually sold it for a loss as it kept having issues.
Good luck on your project.
Tom
Tom
XKR-S, can you email me at anhandrew@gmail.com? I have a few question about your car.
Thanks,
Andrew
Thanks,
Andrew
Thanks,
Andrew
Thanks,
Andrew
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
