2007 XK Cooling System Service
Another one for the list - AJ812140 which is the throttle body to heater inlet hose that runs from the front to the back of the engine and sits in the engine valley.
I have just bought one for my car because my supercharger is about to be removed to have the torsion coupler replaced The hose was only £2.99 plus shipping on EBAY so it made to change it as the 'valley' hose seems to be a common fault on earlier models.
Happy Sunday,
Dave
You may not have found it because it is listed on the throttle body page. The picture is wrong on there as well.
Not so sure you need to replace every single rubber hose. Just replace those which are often noted on this forum.
Hoses/seals leak/fail under pressure. Many pre-war cars had cooling systems that operated with no pressure cap. Boiling point was 212F (sea level). Presurizing the system allows a higher boiling point, but also stresses all rubber hoses. Classic car collectors have often added pressure radiator caps; and found early hose failure.
Hoses today are much more robust.
Consider going to a system with zero pressure. Check out Evans Coolant. It has a much higher boil point than conventional coolants; and operates with no pressure. I have had it for years on my '07 XK with no troubles, leaks, etc.
I love Evans.
I'm going to put it into my XKR in the spring as I have to replace some coolant lines anyway. This wouldn't have happened if it'd had Evans earlier, as nearly zero system pressure.
