2007 XK Electrical Central Junction Box Failure
Old 07-06-2023, 04:30 PM
Sean W's Avatar
Received 4,267 Likes on 2,384 Posts
Originally Posted by Kevin7720
One thing I’m not sure of is if it will recognize the whole Central Junction Box as having a problem or one aspect of it. I can only go off what the three mechanics have told me so far because I haven’t hooked up machine yet. I was trying to obtain a battery charger that has high amps of about 30-50amps. I’m also considering using jumper cables from a car running if I can’t get the charger.
Your goal is to replace the CJB so this will be a service option, but yes it's always good to run diagnostics first. SDD will tell you if there is a circuit issue and it will also let you view the guide to drill down on that issue so it could guide you to a relevant relay.
Regarding the battery back up. It's been covered ad nauseam here. You want something that will give you 13.1 volts steady and low noise. For something as big as swapping out a CJB, invest in one. I use the Astron RM50 But you should be able to get by with a 25 amp. Check out eBay. Don't use another car. Jaguar advises against ever connecting to another car unless absolute emergency. Connecting to another car can damage your engine harness if left on too long.
CA Jag (07-07-2023)
Old 04-22-2024, 09:39 AM
Klaus0401's Avatar
Hi from Germany,
@ Kevin, did you find the issue?
My keyless entry have the same problem. The FSJB don't work anymore.
The third Jaguar found the faile, its worse.
David N. Warner
08-27-2022 06:05 PM
Susie Q
US Western
10-25-2021 12:56 PM
datriani
03-25-2021 10:47 AM
brownrid-an
08-12-2014 07:51 AM
SirJag
03-12-2011 10:47 PM
Quick Reply: 2007 XK Electrical Central Junction Box Failure
