2007 XK Electrical Central Junction Box Failure
One thing I’m not sure of is if it will recognize the whole Central Junction Box as having a problem or one aspect of it. I can only go off what the three mechanics have told me so far because I haven’t hooked up machine yet. I was trying to obtain a battery charger that has high amps of about 30-50amps. I’m also considering using jumper cables from a car running if I can’t get the charger.
Regarding the battery back up. It's been covered ad nauseam here. You want something that will give you 13.1 volts steady and low noise. For something as big as swapping out a CJB, invest in one. I use the Astron RM50 But you should be able to get by with a 25 amp. Check out eBay. Don't use another car. Jaguar advises against ever connecting to another car unless absolute emergency. Connecting to another car can damage your engine harness if left on too long.
CA Jag (07-07-2023)
datriani
03-25-2021 10:47 AM
brownrid-an
08-12-2014 07:51 AM
