2007 XK Engine ECU Pinout Diagram
Old 05-11-2015, 03:01 AM
Dom_2014's Avatar
Default 2007 XK Engine ECU Pinout Diagram
Hi all!
I was hoping someone out there could help me out, I'm looking for the connector pinout diagram on an ECU.
The ECU is from a 2007 XK (X150) 4.2L V8 NA, it's the one with the FL072 BLack 58 pin connector.
I have the electrical guide for the car but it doesn't have the pinout diagrams for the various connectors.
Thanks in advance for any help offered!!
Old 05-11-2015, 05:36 AM
u102768's Avatar
Received 1,490 Likes on 908 Posts
If you have the electrical diagram them you should just be able to search for FL072. That connector appears on a number of pages and, if you weren't aware, the number after the slash for each entry is the pin number.
The attached should help as well.
Dom_2014 (05-12-2015)
Old 05-11-2015, 10:09 PM
CleverName's Avatar
PMed
Old 05-12-2015, 06:16 AM
Ngarara's Avatar
Received 1,126 Likes on 797 Posts
I'm annoyed - I know I've seen a diagram of the pinouts, but I can't find it. Hopefully CleverName has supplied what you need.
Old 05-12-2015, 07:22 AM
Dom_2014's Avatar
Default Thanks!
Thanks guys!
My main confusion was that any other Jag wiring diagrams that I have used in the past had a section at the end with the actual connector pinout diagrams, where as the ones I had for this didn't.
All sorted now, after a bit of cleaning I realised the ECU has numbers on the connector.
Thanks again!!
Old 05-13-2015, 07:22 AM
JagV8's Avatar
Received 4,535 Likes on 3,944 Posts
The later MY guides (usually/always?) have both connector details & more but not always where you first look! Some are before the main circuits, others the page before/after each circuit page
Bcrary3
09-12-2021 05:41 AM
Rlover
03-30-2016 10:04 PM
mcdutch
09-04-2015 03:38 AM
obwoodie
09-03-2015 07:45 PM
TC Johnson
09-02-2015 09:30 AM
Quick Reply: 2007 XK Engine ECU Pinout Diagram
