2007 XK Front upper control arms
Is it the balljoints or bushings that are bad? The bushings can be replaced. If you just want to buy a full arm, get ready to be bent over a barrel:
C2P25603
C2P25604
Jaguar XK Control Arm - Control Arms - Genuine Mevotech - 2007 2009 2008 07 09 08 - PartsGeek.com
C2P25603
C2P25604
Privilegedjaguar (06-20-2022)
No you cannot unfortunately, but they aren't hard to find for less than the link above. Lemforder is OEM:
http://www.ebay.com/itm/Jaguar-S-Typ...JZPAm5&vxp=mtr
There are others. Here is a cross interchange:
http://www.kakapart.com/oem/partscro...r-3374701.html
I would avoid Deutsche Parts USA due to their BBB rating.
Jaguar S-Type XF Front Upper Right Suspension Control Arm & Ball Joint Assembly | eBay
LEMFORDER 33747 01 Track Control Arm
I ordered a front set from Ford which will be stamped Jaguar and made in the U.K. I recently received a set of rears from Ford for a fraction of what Jaguar charges and they were indeed Jaguar parts not Ford.
Sorry didn't quite understand your answer. Are the cross references correct in that all of the front upper arms are interchangeable or are they unique to the F-type/x150?
https://www.jaguarforums.com/forum/x...l-arms-187168/
oldish git
27
07-24-2020 02:05 PM
chelmswood
06-15-2017 08:17 AM
