2007 XK - No Power Anywhere
Locking the doors will manually shut off Convenience Mode. If you park but don't lock the doors, Convenience Mode will automatically shut itself off after approximately 25 minutes - and that delay sucks power from the battery. Even when Convenience Mode is off, the clock and other modules will continue to draw power, albeit small.
I can’t tell you the minimum size battery needed to start the engine but , with all the electrics and computers, there is a big load in addition to the starter. A tip top battery is essential.
People have made a false floor to level the bottom of the battery with its mounting area and then slide it in. Lots of threads on installation of the battery here. I found the hold downs removal and installation more aggravating than loading the battery. And I’m old.
My two year old Interstate battery crapped out last summer. All fine, fine, fine then nothing. That surprised me as well. New, fully charged battery solved the problem.
As StuartS notes, locking the car (and storing the fob well away from the car) preserves the battery charge. Most people regularly use a maintainer.
The battery junction box with the 3 mega fuses is on the left of the battery by the negative cable. The 400 amp fuse is associated with the starter and the power + cable for the starter runs through the remote jumper post connections via isolators.
Thanks Mike! What does storing the FOB away from the car do to preserve the battery if the doors are locked. That is certainly one thing I was not doing as I kept the keys in the cup holder all the time. I was aware of locking the doors so i am surprised I forgot to do this, apparently multiple times as I was working on various things in the car.
V7Sport (06-13-2022)
That is very interesting about the power draw. That CTEK 3300 looks similar to the Schumaker charger I was using but yours I see is a $100 charger so it must be a higher quality charger. I literally have 4-5 chargers to chose from since I have bikes and other toys. Some are the larger sized maintainer / charger /starter type with selections for battery type and others that are the smaller motorcycle auto trickle chargers. If I do have to get another battery would I be better off with a lithium battery since it can handle up and down in voltage levels / recharges better? I see some either you or someone has a Lifepo battery which is lithium I thought. Would be interesting to know what amperage model that is if this is the better way to go.
Here is my theory. The security system is looking for the fob even when locked. The fob tickles the security system to be ready to open the car when the fob is sensed. The constant presence of the fob increases the power draw as the security system is in the ready to open the car mode constantly. Probably not a lot of extra power but it doesn’t help the battery.
jahummer (06-13-2022)
#32
Received 1,103 Likes
An AGM battery does not belong in an '07. You'll get away with it but there is no BMS nor is the alternator up for the job. You will be dependant on external charging.
Similarly, lithium batteries have a different "power profile". Not the right choice for the car.
The good ol' fashioned lead-acid works best in this car. 900 CCA and charged to 12.6v. I leave my car for months on end without a charger and no issues.
bocatrip (06-13-2022)
#34
Thanks again! I’m all for saving some money on a new battery if that is what I need. The alternator point could explain why I have been drawing the battery down more quickly it seems. Using an AGM and always having it on trickle charge then would overcome the lack of alternator output. Go on a long trip and it would seem that you would end up having an issue though. How do you determine if an alternator is not capable of maintaining/ restoring the charge on a battery in a car? All dependent on the amount of draw while running vs. what the alternator puts out I would think.
#35
guy (06-13-2022)
#36
So, for many long continuous road trips, AGM might not be best suited to your application but for short trips or infrequent use, AGM would be fine which's why it worked for me.
Make certain your trickle charger can switch between AGM and flooded, again due to different charging profiles. A non-AGM charge can easily overcharge or have voltage too high.
guy (06-13-2022)
#37
Prior to converting to lithium, mine was fitted with an AGM with higher spec than OEM and had no issues though technically the original specification was a traditional flooded battery. Even when BMS was added in the 2010+ MYs, AGM was not always fitted from the factory.
#38
provided. again. https://www.motortrend.com/how-to/hr...a-agm-battery/
The point to be made is that the alternator in an ’07 is not “geared” to handle to handle the unique requirements of an AGM battery.
This is not necessarily an issue if you prefer to adopt a strategy of providing an alternate charging capability while she is parked. (And I can’t be bothered)
#40
Does anyone actually know what the milliamp draw should be on the battery during convenience mode after turning the car off, and what the draw is after that time for the small items such as the clock... My understanding on many cars is that we would see 300-750 milliamps initially upon connecting the negative lead for powering up capacitors / electronics... but then within 15-20 seconds this would drop to say 25-50 milliamps on a continuous basis which just maintains the clock... If I knew this, I could confirm my cars is within range. And if not, I could pull fuses individually until I found the source of the drain. I am going to hook up a digital amp meter in-between negative and the post and conduct this test when I hook my AGM battery up tomorrow. Just thought I would ask first.
