2007 XK - No Power Anywhere
Old 06-14-2022, 10:37 AM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
I do believe Cambo has a chart. I should have copied it from him, but I failed like a failure.
  #42
Old 06-14-2022, 10:41 AM
M1redskin's Avatar
That's funny! Umm - I'll try to search for this Cambo guy here then. Thanks!
  #43
Old 06-14-2022, 01:06 PM
ram_g's Avatar
Originally Posted by guy
Honestly not sure what position this article is supposed to be underscoring. The way I read it, AGMs (as opposed to “gel” batteries) are treated pretty much the same as flooded lead acid.
  #44
Old 06-14-2022, 01:34 PM
M1redskin's Avatar
Default Battery Drain test on 2009 XK
I fond an excellent diagnostic you tube video on battery drain testing the above. He didn't find anything wrong in this video but it does provide amperage / voltage data over a period of time when the vehicle is shut down. In this case, he replaced the battery and the problem was solved supposedly. Very good video though. I want the meter he is using.
  #45
Old 06-14-2022, 01:38 PM
Sean W's Avatar
Received 4,256 Likes on 2,379 Posts
V7Sport (06-14-2022)
  #46
Old 06-14-2022, 01:59 PM
M1redskin's Avatar
Default 2007 XK - No Power
Wow! That is an extensive amount of battery drain testing information and research on what appears to be quite a common problem on Jaguars. I saved all the pdf files. In my case, I had a run into my battery being dead on my 2007 6 months ago. And I learned on this site that I needed to make sure the door locks were activated and the importance of having a trickle charger on at all times, since I only drive the car every once in awhile. I did take the charger off while in my garage for a week or two with the top down. I was in & out of the car a half a dozen times or so during his period working on my top... I mostly locked the doors I think, but apparently not enough as the battery was dead not even two weeks later. So I need to load test / confirm my AGM 12/20 stamped battery is still good, and then decide on whether to bother with all this testing. Your article on how to charge / bring back to life an AGM battery is worth knowing & trying as well.
  #47
Old 06-14-2022, 03:45 PM
Cee Jay's Avatar
He will be along shortly, no need to search.
  #48
Old 06-14-2022, 07:23 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
This is from the workshop manual but only has quiescent values.
Cee Jay (06-14-2022)
  #49
Old 06-14-2022, 07:26 PM
Cee Jay's Avatar
THERE it is!
Thanks, U
  #50
Old 06-14-2022, 08:29 PM
M1redskin's Avatar
Thanks! I think this is on of the pdf files I seen earlier. I’ll probably do the whole current test out just to see what I get.
  #51
Old 06-16-2022, 05:49 AM
M1redskin's Avatar
Default 2007 - Electrical Power Loss
As a further follow-up to my at first completely dead car, I charged my Super Start 850 CCA amp AGM PLatinum for 3-4 days, had 12.4 volts on it and had it checked out under load as a good battery with a prefessional digital load test meter. Same result with a cheap Harbor Freight hand held 100 amp load tester I have. Put it in and had accesory power like the test battery I tried, but everythging goes dark when hitting the start button. Tried it with the key FOB in the emergency start slot and same deal. Tried it with a jumper on it, same deal. I still think it might be the batteery so I might try a new one just to see. Otherwise I am thinking maybe an starter shorted or ??.
  #52
Old 06-16-2022, 06:52 AM
Barry Leftwich's Avatar
You still haven't tested your rear seat fuse box?Cause your car sounds like it's getting power.The security system is not gone let you power your car to turn it on and will shut everything off which it sounds like it's doing.If you see it's power coming from the battery where your car haven't completely locked you out and the key fob is still working to unlock your doors,then IT'S NOT THE BATTERY!I think the guy have me blocked or else he would've said something about checking it by now🤔but oh well,that would suck if he finds out later on that this would be the case when he could've found out sooner by reading my comment
  #53
Old 06-16-2022, 07:37 AM
jahummer's Avatar
Received 2,380 Likes on 1,490 Posts
Did you say your battery measures 12.4 volts? Curious if you can read voltage at terminals when you press the start button. Also have a look at this recent thread if you’ve not already. Also have you tried a high capacity jump pack or jump starting from another vehicle?
  #54
Old 06-16-2022, 08:17 AM
M1redskin's Avatar
I double checked the voltage w/o it hooked up and it is actually 12.65 volts. I talked to a guy / company that only does batteries. According to him, AGM's must be at 12.66 volts which mine is certainly close enough. He has a better tester which tests to a much deeper draw and does not trust the digital meters at places like O-Reilly or my cheap Harbor Freight model. He stated that with the battery having dropped so low (below 10 volts) perhaps multiple times, that it could still be the battery. I know others think it is not the battery but I am not convinced yet. If it checks out this last time, I will check the fuse box, see what the voltage drop is, the current...
Barry Leftwich (10-08-2023)
  #55
Old 06-16-2022, 08:18 AM
M1redskin's Avatar
Also, I have not tried a high capacity jump starter or from another vehicle so that is a good idea. I'll give this a go as well once I confirm the battery at this local battery shop. Then to all the other steps as well.
  #56
Old 06-16-2022, 08:20 AM
jahummer's Avatar
  #57
Old 06-16-2022, 12:07 PM
M1redskin's Avatar
Just to clarify as well, at no point in these past weeks did I touch the positive cable to negative or any other pattern. Just positive post to positive cable and then negative post to negative cable. So no hard rest in other words I believe.
jahummer (06-16-2022)
  #58
Old 06-16-2022, 12:09 PM
jahummer's Avatar
Either way, glad it's been sorted. Sounds like the battery's fine too.
JeremyB
07-26-2024 08:36 AM
spuds1956
02-05-2023 01:03 PM
Jtmenniti
08-17-2019 06:07 PM
hal
09-05-2017 04:23 PM
jack2828
12-18-2015 05:41 PM
Quick Reply: 2007 XK - No Power Anywhere
