2007 XK P0410 code
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Read somewhere this was not a real trouble code on 07 XK so I reset. Code returned and I now can not locate fuse to check for real trouble. Any suggestions on where to look. There is a fuse labeled active exhaust, think that could be it? Will check in AM. Checked active exhaust fuse it was ok. Will try and locate [secondary injection switch valve a] and try and see if it is shorted.
