2007 xk speaker wiring code
hi, I am trying to add a amp to my 07 xk with standard alpine stereo I found a sub woofer and I want to add a new amp . does any one know the speaker color codes. I found the speaker connector under the passenger right lower kick panel . when I unplug this all the speakers go dead so I know this is the main junction plug for the speakers I just don't know color codes for right,left.front ,rear ect.
2007 xk speaker wiring and factory sub woofer
I want to Thank You again . Your info has been a great help. I found a factory Sub Woofer mounted in the factory enclosure on Ebay but it was missing the alpine amp, so I am adding a single channel amp for the sub woofer. the sub woofer enclosure mounts under the passenger foot well carpet. there is a kick plate that you remove and under that there is a honeycomb backer made out of foam. When you remove the foam backer the factory sub enclosure bolts right in. It is a little strange that the carpet goes right on top of the speaker, not sure if the carpet needs to be cut out around the woofer grill or not. Subs always seem to be buried behind something or other. If I cant hear it after I hook up the amp I guess I will know.
u102768 (10-14-2014)
FS[SouthEast]: 2006 and 2007 Jaguar Media Press Kits
SCMike
09-09-2015 09:30 AM
