2007 XKR electrical failure
Hiya.. had the car about 15 months now without any major problems. Approx 2 months ago the battery died but after a quick jump everything has been fine since.
This evening out of nowhere, started the car fine but the lights looked a bit dim. Thought they might have been a bit grubby due to recent weather etc. Pulled away and after 3 mins or so, warning lights started.. first battery not charging, then brake fault, airbag, gearbox warning etc lights went off, power steering went, computer shut down, windows wouldn’t do up. Car was still driving at this point as we tried to
limp home.
Engine finally gave up but couldn’t turn the lights off,
get the key out of the slot or open the boot.
jumped started and everything came back on but,
disconnected the leads and the computer went and couldn’t get the car in drive.
turned it off but still couldn’t turn the lights off etc. Currently have the battery on charge but I don’t hold
much hope ..
any common problems or advise on where to start?
oh also had a squeak coming from engine area that want there before
many thanks
limp home.
much hope ..
many thanks
It sounds as if you have a dead or dying battery issue. XKs are very persnickety when it comes to batteries. When you have a failing or failed battery you get all sorts of weird occurrences. Have your battery checked, it should show better than 12V of charge at rest. How old is your battery, if more than 3.5 years, replace and make sure the new battery is fully charged before installation. Also, if your SK is not a daily driver, look seriously at getting a CTek or some other kind of battery tender and keep your car hooked up to the device when the car is not in use. There are several threads on the subject so you can use the search box to get more information.
It sounds like your are not using a battery tender? There are some on our forums who will always report they leave their Jaguars parked up for months with no battery issues but there is no doubt that use of a CTEK prevents spurious electrical issues. A new battery + fully charge it + keep it on CTEK when the vehicle is not in use will help avoid a repeat of situations like this.
So put a new battery on and started her up. Everything came on but the battery not charging warning is still on. Unfortunately I don’t have a volt meter.
should I expect it to just go out with a new battery fitted?
should I leave the car idling for bit to see if it resets itself, or drive it?
Queen and Country (12-18-2019)
There are several possibilities why this might happen. Just went through a similar search with my MY14. Turned out to be two things beside the worn out battery (4-5 yo). There was a bad cable (red) and my alternator was gone. They (dealer) said the bad cable might have been the cause for the alternator expiring prematurely. Good luck, dealer cost to repair around $1800. Parts were new battery, alternator, cable and the labor.
JerseyJag
12-17-2017 02:04 PM
ferraripete
09-17-2016 11:42 PM
Vancouver777
03-12-2016 02:04 PM
