2007 XKR needs help
I'm new to the forum, I have a beautiful 2007 xkr that sounds like it's misfiring. More likely a rough idle, I have replaced the air mass sensors, the barometric pressure sensor, replaced pcv-valve, replaced all 8 spark plugs-ngk, then 8 Delphi coils. Then 4 oxygen sensors, spent over $2200.00 at a local mechanic, my car still has the check engine light on, still running lean. So frustrating, but I bought this car for $11,000.00 with 85000 miles on it. I just want to get it through Marta and get that check engine light off. Please any help anyone can give to me to get these lean codes off, without going broke, or continue to sit in the garage.
I have no idea when that fuel filter was changed ? I hope the mechanic gap the spark plugs. I was told air mass sensors causing lean codes, also performed smoke test, no vacuum leaks.
Teddy here, I'm in Nashville, bought a bottle of Techron and put it the car, also got all of the codes. I'm curious, I was asked has this car been driven since the repairs? I haven't driven it far, maybe 10 miles. Someone said the car needs to be driven at least 60 miles for computer to reset itself ? Is this true? Here are the codes--( po300-thru-po308-cylinder1-thru-cylinder8-misfire detected. Next-po316-misfire detected in startup (first1000 revolutions)-po174-system too lean(bank 1)- po101-mass or -volume air flow circuit range/lerformance--po2105-throttle actuator control system-force engine shutdown.Should this car be driven on the interstate if it's misfiring ? I hope this information is helpful !
Received 2,626 Likes
If DTC P0300 is present accompanied by random misfires on all cylinders, the very first thing to do is check fuel pressure. Under no circumstances is the vehicle to be operated under conditions that cause the MIL to flash as catalyst damage is occurring.
If you don't already have it, here is a link to the X150 Workshop Manual:
https://www.dropbox.com/sh/gn6p1upuh...S531fLxta?dl=0
Refer to the Manual for the fuel pressure test procedure.
What is the age of the battery? The battery must have a minimum of 12.6 volts when checked across the terminals with a voltmeter whilst the ignition is in the OFF position. If the voltage is less than 12.6 volts, charge the battery for at least 8 hours between 2 and 5 amps then perform another test. If the voltage is still less than 12.6 volts the battery must be replaced. A failing or weak battery is the often the cause of random DTCs and other electrical 'gremlins' chased on these forums.
