2007XK Rear Brake pad and rotor wear after 20k miles.
I decided to have a local independent shop do my oil change at 20,000 miles. As always they come back with other items they've found out of spec. No problem with that but I'm both surprised and concerned at what they found. The rear break pads and rotors are essentially worn out. Pads are at 3/32 which OK they wear out and 20k miles is low but for the rotors to be below minimum thickness blows my mind. Firstly the fronts are fine at 11/32" on the pads and the rotors are well inside the spec. Secondly I don't drive it extremely hard. Yes I have my moments but I'm not heavy on the brakes.
Anyone found this on their XK or ever heard of it before? Is this not unusual? It suggests to me that there's a bias of braking power to the rear which doesn't make sense.
Cost to install none OEM rotors and pads $600.
Any thoughts, advice, explanation or suggestions most welcome.
Steve.
Steve.
Received 2,190 Likes
KarimPA
09-12-2015 08:15 AM
