2007xkr rear speaker
Received 4,280 Likes
sktslls, I have moved your post from the General tech section to the XK/XKR section for better visibility/response. I see you are new to the forum so when you have a moment, please go to the New Member section and post an introduction
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Also, in case you are not aware, you cannot just plug speaker inputs into an amp unless it specifically has speaker level inputs or you add an external line level converter.
You should add whether you have a Coupe or Convertible and if this is the 6 Speaker Standard or 7 Speaker Premium installation.
