2008 headlight adjustment
Well,
Out of caution I pulled one light assembly to see what makes things work. There is a threaded shaft and it was intact so I felt better about turning the hex drive more revolutions. Once re- installed I ended up turning the top/center adjuster 10 full rotations and achieved the desired positioning. It seems that toward the end of the adjustment shaft there is very little horizontal movement, hence my 1st impression that the light pattern was not affected by this 'adjustment' .
My bad and for those curious, yes there is l-r and u-d manual adjustment available for the non active light assemblies (early xk150).
wj
wj
