2008 Jag XKR - Key FOB programming-New battery
Received 2,011 Likes
aacpa15215 (04-12-2017)
If the SmartKey fob worked when you bought the car, the problem is probably with the new CR2032 battery or with the way it was installed. No programming is needed after a new battery is properly installed in the SmartKey. Beware of used SmartKeys; they usually can't be reprogrammed for a different car.
See:
https://www.jaguarforums.com/forum/x...orking-155914/
https://www.jaguarforums.com/forum/x...cement-117974/
See:
See:
See:
You can find them on either Ebay or Amazon. Be aware that you will probably have to go to a Jaguar dealer to get it programed. There are several threads on the forum dealing with keyfobs. Suggest you go to the search box in the upper right corner and type in keyfob and/or programming keyfobs.
If you buy a used smartkey, be sure to GET IT IN WRITING that the key has been cleared and is guaranteed to be reprogrammable, and is refundable in full. Pay ONLY by credit card, so you can dispute the charge if need be based on the written guarantee by the seller.
Note that the conventional emergency key blank is available separately on eBay: Smart Key Blank Insert for JAGUAR X S-Type XF XK XKR Remote Key Case Shell Fob | eBay That key is cut on both sides, and usually requires a laser cutter to do so. Cost for a qualified locksmith to laser cut the blank is typically around $30, as the laser cutting machine is expensive and they want to recover their cost.
Sean W (05-06-2017)
My dealer here wont accept any non-by-them-ordered keys.. so I'll have to put in the cash for my spare ..
also.. the previous owner probably wanted her make-up or something in the glove compartment... as the books had to make room for it.. so no spare key, no booklets.. I tried searching for new booklets, but those are outrageously expensive (over $500!)
https://www.jaguarlandroverliterature.com
You can get an English (or Arabic) set for around $109 or just the owners manual for $55.
As many have mentioned, no re-programming. I have found differences, if ever so slight, between battery mfgs that cause one to think the battery is a "dud" or the FOB is dead. I had this issue within the past couple of weeks when I received a low key fob battery warning.. I tested a new battery and it was beyond the 3Vs, but would "not" power the FOB. I switched between FOBS (have two) and it didn't work. I was thinking it was the FOB. Tried again, and it worked? Now, they both are fine, so, I'm not sure what the heck is going on....
When I bought my Jag the seller gave me only one key, no info about another. Well, then I noticed that there is a place for a key in the middle compartment behind the cup holders...and there it was!
Sometimes my XK says "key not found" but putting it into that hole makes XK find it. Does this mean weak battery?
I've encountered a similar situation, but noticed that it was winter time, and the key was cold. Pulled it apart to check the battery, showing right at 3v, warmed the battery up in my hand, reassembled and started working. I haven't encounted that when its been warm. Electronics can be a myth sometimes.
I am the original poster of this thread. Here is what I found out. Called the local Jag dealer service department. When you replace the battery, you need to do it pretty fast within 30 seconds to retain the programming for remote operation. If not done in time, it loses the program and will only operate when inserted into the key slot in middle compartment. I took a little longer to insert the new battery, as I was cleaning the dirty case of the FOB. Now I may have to go the dealer for programming who said $ 165 or to a local Jag Sports Car Shop $ 150. New key plus programming was quoted as $ 480. Just a rip off I think. But then we own Jags!
The key still works when inserted into slot and I have the other key that works fine.
............ When you replace the battery, you need to do it pretty fast within 30 seconds to retain the programming for remote operation. If not done in time, it loses the program and will only operate when inserted into the key slot in middle compartment. I took a little longer to insert the new battery, as I was cleaning the dirty case of the FOB. Now I may have to go the dealer for programming who said $ 165 or to a local Jag Sports Car Shop $ 150. New key plus programming was quoted as $ 480. Just a rip off I think. But then we own Jags!
