2008 XK - help upgrading Navigation/iPhone system
#361
I've read every single post in this thread, all 358 of them. I still don't see any definitive answers to three specific questions.
1. Can you control Cooled Seats
2. Can you clear in-dash warnings, such as TPMS fault
3. Danged if I can remember the third one as I just woke up. Any help?
If I can't use those features, I won't get one of these things.
Cee Jay (03-26-2021)
#362
Anyone has a clear picture of the "Can bus decoder", or knows exactly what text is written on it?
Referring to this thread..
#363
Cabrio Bob (03-28-2021)
#364
#365
Guys, managed to install a new screen. Everything works, except radio... Which is not surprising, because I don't have a free cable in OEM setup to connect a radio to. Where/How did you connect a radio antenna? I have a part from a new unit, but don't know where to connect it...
PS. Cooling seats - don't work I'm afraid (only heating). Dashboard errors "clearing" - have not found a place to erase them.
#366
#367
#368
regarding seat cooling, make sure you have the correct vehicle and model year in vehicle settings. Also try 2009 XF or later since you have a 2010. The only thing those settings change are the climate I think.
"Dashboard errors "clearing" - have not found a place to erase them."
do they even show up on the touch screen or the gauge cluster only?
#369
I have it as in this picture, but don't know what to connect to it... I don't see any FAKRA connector available from an OEM device. Help with that one would be highly appreciated.
Original setup was and I guess one of these green or brown connectors would be for a radio...
You mean CCF setting or a setting inside a tablet? If the second option - how to get there?
On a gauge cluster only. I have one now (tpms broke into two pieces inside a wheel and tpms is raising a flag - not communication with a wheel). On an OEM screen I used to have a red triangle which allowed hiding these errors from an instrument cluster.
#370
#372
#374
What have you lost?
1. Ability to extinguish faults showing on instrument cluster. Is there an icon on the screen to do this like the factory screen? This can be tested my forcing a TPMS fault my lowing the tire pressure in 1 tire.
2. No heated windshield icon? I have a heated windshield which is useless because I never use it, but it is a factory feature.
3. Simple plug and play for backup camera (especially for 2012-2015)?
4. Is the screen visible wearing polarized sun glasses? Someone had mentioned the screen was not properly engineered to be viewable wearing polarized glasses.
1,, No but using a autel odb2 whit maxiAP showing some digits in real.
2,, Yes like u wrote,, windchield its lost,, but never used it anyway.
3 , Huh? backupcamera that comes with the package works perfekt.
4 ,, Yes there can be problems with screen visible,,,, but sometimes we have to give for have, and i usally dont check screen when driving.
Anyway I think its a fun mod to do,,, It helps to be little crazy I love the drivingexperience of this car,, so little better sound is always welcome
HOT!!!! hehe
#375
#376
Damn either I'm blind or I really don't have a radio antenna cable nearby... Made a huge disassembling to find it and so far not even close... Anyone with MY10 with an experience about radio antenna?! Sean W - counting very much on your suggestions.
I will plug OEM player tomorrow to check if it plays radio without a fakra plugged in to determine whether it was there and disappeared (as radio worked for me) or I need to provide an aftermarket antenna to a screen (or somehow provide AM/FM signal from an OEM antenna to a screen).
#377
I wish I could help. I have an 07. I looked at the wiring diagram for the 2010 onward and it shows the same connection so I.m thoroughly confused. You might want to start a separate thread as many guys are probably tired of this thread and don't look to it anymore. Simply ask where the antenna connects at the center console. I'm certain others know.
tmich (03-29-2021)
#378
My installer has reached an impasse. We know that the unit I bought from Guangzhou Electronic Technology Co., Ltd works when powered up and that the Jaguar system works properly. However, we cannot get the two systems to interface. My XKR, a 2013 vert has an upgraded Bowers & Wilkins system.The installer has tried everything he can with no positive results. I am including several photographs of various wiring which seem to have nowhere to go. He has scoured this thread and made several other searches with no positive results. Please ignore the first photo. It is redundant.
label on Jaguar radio
These don't seem to match up with the built in wiring loom
Cee Jay (03-31-2021)
#380
Aftermarket wires remain loose. Light gray and blue OEM sockets are not needed too. Brown is a radio I believe (use an aftermarket connector fakra to din) - lucky you (I don't have it in my car - at least visible). But I might be wrong with a brown one as I haven't seen a proper radio cable (but it's a fakra cable for sure). If it's from a top of a OEM radio it might be not needed too.
I guess you are very close!
ps. I did it in 2h having all the posts (except rear camera, which I left for a later stage - retrofitting OEM one). Critical thing is to cut a white plastic socket (aftermarket) connected to a hazard lights - to fit it with a black OEM one. The rest is plug and play with some unused sockets/cables.
ralphwg (03-31-2021)
