2008 XK - help upgrading Navigation/iPhone system
Old 12-09-2020, 07:03 AM
peterv8's Avatar
Okay, need some help Kurt!
Which connectors did you put the 2 most loop connectors on?
  #142
Old 12-09-2020, 08:42 AM
peterv8's Avatar
I'm afraid I'll have to cut this connector off for me to get sound!? Doing some homework and looked at the schematics of the infotainment and know that these are the one's I need as I have the base audio unit.
On the android unit the speaker wires are color coded, white, grey, green and purple. Four are solid colour and four have a black line. Which of them is the positive? Sent a question to vendor asking which colour goes where and also about speakers not plug and play if you have base audio system!
somenavyguy (02-21-2021)
  #143
Old 12-09-2020, 11:59 AM
Sean W's Avatar
Received 4,256 Likes on 2,379 Posts
Hi Peter. The 12 pin connector are the speaker wires, correct. The connector is identified as IP058.
The other 14 pin connector is identified as IP057 and pin 1 is positive from the battery color is N/W (N=brown - W=white)
There is no amp on the base system, just the integrated audio module that you have pictured. Would it help you if I posted the wiring diagram for the base entertainment?
EDIT: oops, I reread and see that you have the schematics.
The following 2 users liked this post by Sean W:
peterv8 (12-09-2020), somenavyguy (02-21-2021)
  #144
Old 12-09-2020, 12:03 PM
peterv8's Avatar
Thanks but no need to upload, I have the wiring diagram and have found what colour is what. :-) Waiting answer from the vendor about the speaker wiring on the android unit.
The following 2 users liked this post by peterv8:
Sean W (12-09-2020), somenavyguy (02-21-2021)
  #145
Old 12-10-2020, 10:08 AM
LoudHogRider's Avatar
The short answer is the two on your right. The video plug that is part of the wiring loom with the green connector is the one that goes into the "Head Unit Replacement" component provided by the Seller (see pic below):
Put the loop connectors on the other two, and you've solved that part of the riddle.
The following 2 users liked this post by LoudHogRider:
peterv8 (12-10-2020), somenavyguy (02-21-2021)
  #146
Old 12-10-2020, 10:11 AM
Originally Posted by jahummer
Unless you can’t live without the wood, changing the center console bits to piano lacquer would go along quite well with the modern screen and solve the fake wood issue. I love burl woods and certainly couldn’t settle for simulated finishes.
One of the options when you order it is "wood" vs. "black" trim. I'm like you - I love the wood look in my Jaguar, so I passed on the black option, but you're correct in stating that going with that black option for the trim piece would have probably just blended in with the other black/super dark gray elements in the OEM dash. I'm still OK with my choice, and it get's less noticeable (to me) every time I drive the car now.
jahummer (12-10-2020)
  #147
Old 12-10-2020, 10:18 AM
My vehicle has the Bose + amp setup, so mine were direct plug-n-play on the speaker wire loom. I added to the mess behind that dash by foolishly hooking up the old ACU wiring looms (they do nothing right now), but everything snapped directly into place with my new screen connectors.
  #148
Old 12-10-2020, 10:24 AM
peterv8's Avatar
I bought a while back a can of spray to darken rear lights(blacken out), I used it for something else. I'm going to try this on my trim piece and maybe by darkening it will look better. 😊
I can't find any burl walnut wrap that is close so might end up wrapping all pieces in carbon fiber or something. 😊
LoudHogRider (12-10-2020)
  #149
Old 12-10-2020, 11:31 AM
Sean W's Avatar
3M makes a gloss black vinyl that one member used (Peter aka Bruce the Quail) and he said it's a great match for piano black, following Jahummer's train of thought.
  #150
Old 12-10-2020, 11:36 AM
peterv8's Avatar
Just a warning!
Don't buy from my vendor. ZWNAV factory store on AliExpress. I can hardly get any answers and if he reply's it takes at least 2 days!
  #151
Old 12-10-2020, 06:42 PM
  #152
Old 12-10-2020, 08:31 PM
Sean W's Avatar
Well it could be the Images in this thread have grown on me. It could also be the Covid Lockdown talking or maybe the whiskey but I'm placing an order. I included the TPMS with my order. Thanks for the heads up on your vendor Peter. They were one of 4 on my list. Deleted them quickly.
Did anyone have customs fees to deal with or just the long wait times?
The following 3 users liked this post by Sean W:
jahummer (12-10-2020), LoudHogRider (12-11-2020), ralphwg (12-10-2020)
  #153
Old 12-11-2020, 07:41 AM
Bill Mack's Avatar
Sean, say it ain't so! You've done such great work on the GVIF/Android box solution, and now you're getting a divorce? Opting for the prettier model?
It'll take me a while to get over this one.
Cee Jay (12-11-2020)
  #154
Old 12-11-2020, 09:11 AM
Sean W's Avatar
I will be keeping all the OEM and my GVIF stuff Bob, in case I want to revert or more likely in case I sell and a buyer wants OEM. But really, after I set up GVIF and incorporated touch, sound, GPS, others did the same with Arduino. Ultimately, Cambo came up with, in my opinion, the next level solution that retains the OEM look and that makes what I did look prehistoric. I may end up disliking it but I do loves me some electronic challenges.
Bill Mack (12-11-2020), Cee Jay (12-11-2020), LoudHogRider (12-11-2020)
  #155
Old 12-11-2020, 12:35 PM
mhminnich's Avatar
That's three! Before long we'll have full support on the forum!
  #156
Old 12-11-2020, 01:21 PM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
If it ever comes down to something being essential-ish that's not on our cars already, like Android Auto or whatever, I may consider this or similar.
The new Bugatti Diva just came out, and it has Zero Big Screen stuff as to never go Out of Style with an antiquated interior scheme.
  #157
Old 12-11-2020, 04:13 PM
A couple of updates from "insights" gained in the last day or so:
1) The "speaker" device that I really couldn't decide what it was for ... has a purpose: it's the microphone for the hands-free bluetooth telephone operation. My "epiphany" came today when I was traveling to the grocery store talking with a buddy, and he asked me where my new mic was located (behind the radio, dangling on some wires).
Me: "Why do you ask?"
Tim: (Because his name is "Tim"): "Because I can hear your motor and your turn signals better than I can hear you. Call me back when you move that thing."
Me: "Well ______! That means yet I've got to pull that thing again!" (announcer's voice: "It's 4 bolts and one trim piece, you baby.")
That thing back there that looks like a speaker - apparently it's apparently the microphone!
2) Copying off my iTunes Library to a USB flash drive enables me to use the native "Music" app on the main page of the screen. It sounds as good as an iPod connected to my old ACM connection, so I'm happy with that.
All for now. More "epiphany's" as they occur.
  #158
Old 12-11-2020, 04:49 PM
Sean W's Avatar
peterV8, I hope you're taking detailed pics as well on your install?
  #159
Old 12-11-2020, 04:54 PM
Luke Martin's Avatar
Originally Posted by Cee Jay
Both of those guys posted ONLY about this infotainment option from Jump. Right off the bat they acted sketchy, and you notice neither are on here now. This has happened before with products NAVCRUEL sells, a new member joins and posts numerous things about how GREAT stuff is, then they vanish. A couple have been banished also, thanks to an observant moderator or admin.
You're good, dude. If you DO go for this option, I'd love to hear what you have to say about it. I do agree that the interior of our cars is quite a bit outdated on the technology front.
I thought I was pretty detailed , went to all the trouble to explain the experiences to help others but yet still be labelled as sketch ? Seriously ..... it still baffles me ...... I even followed up and answered as many questions as possible ....
  #160
Old 12-11-2020, 05:06 PM
really ??? What was suspicious about sharing and being one of the first people to fit this kind of screen in the car and share the details and experiences about it ??? With pictures , answer people’s questions and try help others ???
Originally Posted by Stuart S
Kurt,
If you buy it, do so with the knowledge that if it doesn't work to your satisfaction, you are up the proverbial creek without a paddle. The seller is in China, and once he has your money it is difficult, if not impossible, to get it back.
I agree with what Cee Jay said about "Luke Martin" and "PrivilegedJaguar". Their posts are suspicious, and scammers are professionals at separating people from their wallets.
This is a perfect example of "Buyer Beware!" Know that you can lose all your money and wind up with an expensive doorstop, and if that's OK with you, then go for it! It's your money and your choice.
Just don't tell your wife!
Stuart
Quick Reply: 2008 XK - help upgrading Navigation/iPhone system
