2008 xkr headlight problem
Brewtech (04-14-2023)
What I did was drill a hole, tap the hole and refasten with a bolt - I also covered the connection with paint to protect it from moisture. Make sure you use the right drill size for the tap, the frame is not really thick so be careful when tapping the hole, there won't be a lot of threads after you are done. I think I used a 5/16 of maybe 3/8 bolt.
thanks
G01AL Ground point 1 Lower LH front of engine compartment FRONT LEFT
G01BL Ground point 1 Lower LH front of engine compartment FRONT LEFT
G01BR Ground point 1 Lower LH front of engine compartment FRONT LEFT
You might have to take the engine undercover off to look at the chassis, or it could be behind the wheel.
bgpenguin21 (09-21-2023)
resident_fng
07-03-2022 12:33 AM
