2008 XKR: possible to swap 6HP26 for a 6HP28?
Anyone know if its even possible to replace the OEM 6HP26 trans with a 6HP28? I understand they are both physically identical, so a 6HP28 should just drop in, but what about all the programming and mapping?
There's a couple of reasons I want to do this:
1) Shifts on the 6HP28 are a LOT smoother
2) More max hp/torque headroom. the 6HP26 is rated for only 443lbf.ft max, car is already making 420, and I've been thinking about a twin screw upgrade and several other performance mods that will take me at least into the high 500's.
mosesbotbol (10-15-2020)
Probably not helpful as I have no idea about compatibility, but, I think if anything you'd want to go straight for an 8HP as it can do what you're asking. If you're going to go through the trouble to replace a transmission at all you might as well go all out. It can be found in the F-Type.
steve_k_xk (10-15-2020)
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
Aarcuda (10-21-2020)
rickross
02-16-2014 04:27 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
