2009 XK Coolant expansion tank, funny little hose
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
I'm having difficulty soursing the +- 3 inch small hose the goes from the bottom of the coolant resevoir to coolant system tubing. Different diameter at both ends and moulded shape. I will be replacing the tank itself as several are available from aftermarket folks on line. I NEED THE LITTLE HOSE... thanks, Bob
My understanding is that little hose is not available by itself. Go figure! I bought the whole new assembly and a new expansion tank as they are prone to cracking. I'm also told that you can DYI you own hose by putting a small diameter hose on the lower part and inserting it in a larger diameter hose which you attach to the top. Careful clamping both ends.
2003WHTSTR
04-27-2021 03:19 PM
