2009 XKR Horrible Noise In Reverse - RESOLVED
Hello Everyone,
First of all, a sincere thank you for reading my post & for any provided help/insight in advance. I have a 2009 XKR portfolio series and it was driving as smooth as butter until this morning. The moment I went to back out of my driveway and shifted gears into reverse, I heard this horrific loud rambling noise. Seems like it could possibly be coming from the front because it starts to make a rattle & shake a bit. Any leads as to what it may be?
Much Appreciated,
Chanel
Much Appreciated,
Chanel
Last edited by GGG; 06-14-2023 at 01:34 PM. Reason: Add "RESOLVED" to thread title
Obviously engine rather than drive train. If you open the bonnet and listen you will have a much better idea of where it is coming from but it could well be one of the drive belt pulleys / tensioners or one of the devices driven by the belt like the water pump /alternator / steering pump / supercharger etc.
Richard
Richard
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/500x500/catalytic_converter_dcea16bceb7c888646e1676a07117ed880c10172.jpg)
An increasing problem here in the UK is theft. The honeycomb is coated with precious metals worth a lot of money as scrap.
If its only in reverse, Id listen to the transmission using a mic set up and if its the tranny, start with a fluid change. You dont have to replace the pan for this. Have a shop simply drain and fill. Its less fluid compared to dropping the pan but its plenty enough to be able to fill with some fresh fluid at the correct level. I replaced the pan, and mechatronic 3 yrs ago, then this year, it developed a 3 second delay going from D to R. In a rush, I would gas it and the transmission would kinda slam into R. I had a few liters of fluid replaced, and suddenly the thing is nice and crisp. So try that first. But Im sure its not the transmission from your description. Its probably the belt tensioner, a cat, or heat shield. Cars act different when in reverse. Geometry and frequencies change when going in the opposite way of the usual.
The following 8 users liked this post by Chanel.lucas3:
bgpenguin21 (06-15-2023),
Brewtech (06-14-2023),
GGG (06-14-2023),
Hans Amstein (06-14-2023),
kj07xk (06-14-2023),
and 3 others liked this post.
The following 3 users liked this post by GGG:
If it's in reverse it's left side (drivers side ) I did a write up on this as rack needs to be released....also good news is xf,xj,s-type mounts will fit for along time we thought the xk motor mounts would only fit which are very pricey
C2p17845 I used these recently
derrickonline
09-21-2015 05:34 AM
