2009 XKR Supercharger coolant pump
I'm going to replace my pump when I tear of the blower to replace the coolant lines. I will also change the torsion isolator and the coolant pump since every is out and assuredly will NOT use an OEM pump because More Money and Less Flow. Swapping a few wires on a pump is easy (if you know how), but I'm sure, @XKRAU , that if you brought a new pump and the old pump to pretty much any shop they'd swap the connectors for either free or just a couple bucks.
Veesixjag (09-01-2021)
I can sell you my perfectly good used original pump with 75k miles cheap
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
Veesixjag (09-05-2021)
the MB connector is no longer available , I totally hear you on the solder instead of additional connectors , but these modern day automotive connectors are pretty reliable these days. However if it’s unavailable , then solder it is
Hey! You used 'motor' correctly! I'd buy you a beer for a prize, but you're about 15,000 km away from me. I know, totally obvious, but I tire of people saying 'motor' when they mean "engine".
