2010 to 2012 key fob upgrade via SDD
If you're adventurous, you can crack open your existing key and take out the Transponder Chip, which actually looks sort of like a small graphite ring. Swap it to the new key replacing the existing one. That'll start your car, but as far as using or programming the remote, you're on your own.
Agree the X150 key style never changed 2007-2015, but the innards did change after 2008.5 MY, VIN >B12814. Also remember, if you were successful using the X351 key, it wouldn't fit in the Start Control Unit which may prove very expensive if you can't start he car when the key battery is low or you have a wireless communication problem with the KVM/RFA.
ralphwg (11-02-2017)
