2010 to 2012 key fob upgrade via SDD
Not so long ago, Jaguar had problems with their cars being stolen because the keyfobs were so quickly and easily cloned. To prevent this, Jaguar created a diabolical new design that made it impossible for thieves to quickly and easily clone the key and steal the car. Unfortunately, that also made it expensive for owners to replace a key. No problem, just more profits for your dealer.
From the factory each X150 Smartkey is electronically paired with modules in the car. If that Smartkey is separated from the car with which it was born, it becomes an orphan. That orphaned Smartkey must first be electronically divorced from its parent before it can be reprogrammed and paired with another X150 for it to be fully functional. Both key and car must be present to simultaneously program and pair their modules with the proprietary Jaguar SDD tool.
Yes, a used Smartkey from another X150 can be reprogrammed. I know that for a fact because I bought one on Ebay and had it done.
Did you ever add your key? If so, do you know what the sequence is - I am thinking of getting the SDD to add a new key to my 2011 XKR as I only have 1 key
The Mongoose cable is a few hundred $$$, a dedicated Windows 7 Laptop another hundred or so, the 40 Amp battery power is at least $100, and then there's the program itself, which could cost a few hundred. THEN, if you do it 'legit', you will also need a subscription of sorts to I think TOPIX to have it update all the time. Not necessary, per se, but it is what it is.
"Getting the SDD".............. yeah, it's a lot more involved than just 'getting' it.
Yep, and harbor freight sells usable drill bits also. "koff-koff"
I'd not let the stuff you referenced within the same continent as my car. When JUST THE CABLE costs $200-400, what kind of cable would you expect to get for $10? Many people have bricked their cars using junk stuff. Course, many have NOT bricked also, so give it a shot!
Let me know how it works out.
Tried this . bought a new shape key fob of ebay then melted parts inside the new one so as the chip would fit in , then i would have to get the key that comes with it cut . not a problem . But one problem persists ? if the message put key in dock flashes up your stuffed so binned the idea
#28
#31
#33
Well, perhaps easy after you've done it a couple times. It's easy to open and change out the battery, but I find reassembly a bit tedious. The release slider and spring tends to jump out of place as the other half of the fob is being dropped into place. I'm getting the hang of it now, after doing it twice.
DanJensen (02-12-2021)
#34
#35
#36
#37
hello everyone i am not sure if you guys can help me this is my first time asking question in this chat. i have a 2007 xk convertible at first i was having issues with the battery loosing charge during that time i called a car locksmith to program a new smart key now the car doesn't read the old and the new smart key it doesn't recognize both smart keys and the car is disable it doesn't read the keys
#38
#39
That auto locksmith caused your Smartkey fobs to be unpaired (orphaned) from your 2007 XK. It's like a mother (XK) who can't find her children (fobs). They can be reunited, but it takes the proprietary Jaguar software to do it and both car and keys must be together to do so. Your Jaguar dealer can do it (as well as experienced indie Jaguar mechanics with the software). You probably don't need to buy new keys unless yours were damaged by that locksmith.
#40
George05 (01-25-2020)
Aarcuda
10-12-2019 12:27 PM
Paulie710
03-20-2019 08:02 PM
