2010 to 2012 key fob upgrade via SDD
Old 04-20-2018, 12:38 PM
Stuart S's Avatar
Received 6,290 Likes on 3,452 Posts
Not so long ago, Jaguar had problems with their cars being stolen because the keyfobs were so quickly and easily cloned. To prevent this, Jaguar created a diabolical new design that made it impossible for thieves to quickly and easily clone the key and steal the car. Unfortunately, that also made it expensive for owners to replace a key. No problem, just more profits for your dealer.
From the factory each X150 Smartkey is electronically paired with modules in the car. If that Smartkey is separated from the car with which it was born, it becomes an orphan. That orphaned Smartkey must first be electronically divorced from its parent before it can be reprogrammed and paired with another X150 for it to be fully functional. Both key and car must be present to simultaneously program and pair their modules with the proprietary Jaguar SDD tool.
Yes, a used Smartkey from another X150 can be reprogrammed. I know that for a fact because I bought one on Ebay and had it done.
Old 04-20-2018, 08:03 PM
trkyam's Avatar
Thanks for the replies,
The seller told me it has been released from the previous car
and if it does not work I can return it.
Any tips for using SDD to add this key and remove a key?
(I have one working key)
Old 01-22-2020, 02:59 PM
joedinfl's Avatar
Did you ever add your key? If so, do you know what the sequence is - I am thinking of getting the SDD to add a new key to my 2011 XKR as I only have 1 key
Old 01-22-2020, 03:19 PM
Cee Jay's Avatar
Received 5,368 Likes on 3,180 Posts
"Getting the SDD".............. yeah, it's a lot more involved than just 'getting' it.
The Mongoose cable is a few hundred $$$, a dedicated Windows 7 Laptop another hundred or so, the 40 Amp battery power is at least $100, and then there's the program itself, which could cost a few hundred. THEN, if you do it 'legit', you will also need a subscription of sorts to I think TOPIX to have it update all the time. Not necessary, per se, but it is what it is.
Old 01-22-2020, 03:51 PM
joedinfl's Avatar
Was looking at the SDD offering from britishdiagnostics.co.uk - their kit is about $100 and comes with a cable and I believe works with windows 10 - so additional cost would also be the 40amp battery power. So - if anyone what the sequence is, that would be really helpful - or is it simple to do without instructions?
Old 01-22-2020, 04:49 PM
Cee Jay's Avatar
Yep, and harbor freight sells usable drill bits also. "koff-koff"
I'd not let the stuff you referenced within the same continent as my car. When JUST THE CABLE costs $200-400, what kind of cable would you expect to get for $10? Many people have bricked their cars using junk stuff. Course, many have NOT bricked also, so give it a shot!
Let me know how it works out.
Old 01-22-2020, 04:58 PM
George05's Avatar
Tried this . bought a new shape key fob of ebay then melted parts inside the new one so as the chip would fit in , then i would have to get the key that comes with it cut . not a problem . But one problem persists ? if the message put key in dock flashes up your stuffed so binned the idea
  #28
Old 01-22-2020, 05:28 PM
trkyam's Avatar
Not that hard, I've done it,
SDD only required backup power for flashing modules
keys is fast and doesn't need power provided your battery
Is in good shape.
I bought a used key and programmed it, works fine however
does not work when inserted in the slot.
Old 01-22-2020, 05:47 PM
George05's Avatar
so your out for an evening meal you and the love of your life you escort her back to the car bong bong please insert key in dock (car wont start ) you have to call out auto rescue and she runs off with him lol
  #30
Old 01-22-2020, 06:47 PM
DGL's Avatar
DGL
DGL is offline
Yuck, you want the new cheap key FOB? The original one looks much richer and elegant and you can even put a coat on it to keep it warm.
George05 (01-23-2020)
  #31
Old 01-22-2020, 07:42 PM
trkyam's Avatar
Note this is a spare key, I used the original master key as my daily key, but I have a spare
incase something happends to this key.
Also on 2010 XK\ I have never been asked to insert the key into slot and Ive owned this
car 5 years already.
  #32
Old 01-23-2020, 01:34 PM
George05's Avatar
Looks nice in black overcoat
DGL (01-23-2020)
  #33
Old 01-23-2020, 01:46 PM
jag_man653's Avatar
Originally Posted by Stuart S
That's why everyone should keep a spare CR2032 key fob battery (or two) in their glove box. It's easy to replace.
Well, perhaps easy after you've done it a couple times. It's easy to open and change out the battery, but I find reassembly a bit tedious. The release slider and spring tends to jump out of place as the other half of the fob is being dropped into place. I'm getting the hang of it now, after doing it twice.
DanJensen (02-12-2021)
  #34
Old 01-23-2020, 02:10 PM
George05's Avatar
Why not google up a local Auto key programmer , should only be around $60 bucks or so
  #35
Old 01-23-2020, 02:21 PM
Cee Jay's Avatar
It's a totally different beast, normal programming will not work. Both the car and key need to be programmed to Each Other, not the key to car.
  #36
Old 01-23-2020, 02:57 PM
George05's Avatar
not expensive just seen a programming tool for £80 on ebay seek and ye shall find
  #37
Old 01-23-2020, 11:03 PM
cla's Avatar
cla
cla is offline
hello everyone i am not sure if you guys can help me this is my first time asking question in this chat. i have a 2007 xk convertible at first i was having issues with the battery loosing charge during that time i called a car locksmith to program a new smart key now the car doesn't read the old and the new smart key it doesn't recognize both smart keys and the car is disable it doesn't read the keys
  #38
Old 01-24-2020, 06:34 AM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
You will most likely need to have the car towed to a dealer and have them make you new key FOB's. Also tell the guy who "made you a new FOB" that he bricked both FOB's and should pay the dealer to get new ones. These are not your standard key FOB's. Good luck
  #39
Old 01-24-2020, 10:52 AM
Stuart S's Avatar
^^^^ What he said. Also, read my Post #21, above.
That auto locksmith caused your Smartkey fobs to be unpaired (orphaned) from your 2007 XK. It's like a mother (XK) who can't find her children (fobs). They can be reunited, but it takes the proprietary Jaguar software to do it and both car and keys must be together to do so. Your Jaguar dealer can do it (as well as experienced indie Jaguar mechanics with the software). You probably don't need to buy new keys unless yours were damaged by that locksmith.
  #40
Old 01-25-2020, 03:55 PM
hafren's Avatar
Have you tried the old key in the center console slot?
File Type: pdf
George05 (01-25-2020)
ant17
10-15-2022 06:06 PM
Aarcuda
10-12-2019 12:27 PM
Paulie710
03-20-2019 08:02 PM
Etobicoke sportwagon
02-23-2016 03:24 PM
Mark Saunders
08-23-2015 04:32 AM
Quick Reply: 2010 to 2012 key fob upgrade via SDD
