Hi everyone, has anyone changed the CVD (Constantly Variable Dampers) Dampers/shocks on a XKR X150 5.0 Coupe 2010 - 2014 rear ?
I need to replace mine. What is the correct OEM P/N for this vehicle please?
I've looked at mine and they look original and are stamped Bilstein. I have a feeling C2P17674 may be correct but the info on line is really confusing and contradictory.
The Vin last 6 are: B48974
I think your close but a bit off due to your late VIN?
Here are different rear struts depending on VIN;
This is from the wonderful JPART software.
As you can see you do have the correct part number BUT for an earlier car. I "think" you need C2P22813 instead?
One thing I was not clear on is I don't see any wires attached to these struts in JPART? So I can't say if they are electronically adjustable or not? I think they must be.
