2010 Jaguar XK 5.0 Metal in Oil/New Engine?
#42
The following 2 users liked this post by Cee Jay:
pwpacp (11-13-2019),
U2vertigo1 (11-20-2019)
#43
I know you are in a badaway so its best to keep a clear mind.
Forget about the oil related issues and timing chain.
Look for the known issues, injectors (yes that is oil related, and you used a oil that would cause that, but then again if you made it to 150k miles you are teaching us a thing or two)
Why are you keen to get a new engine. Yes its a direct swap but remember what they say about the devil you know.
Your engine may be in better condition than the one with 50k miles on it. Its not like they have been tested. And because it came out of a more common car, its less likely to have been cared for- the car's demise is proof of that.
The following 3 users liked this post by Queen and Country:
#44
Yes its been a great performer for 149K miles. I am getting a report from the mechanic today which I will share once I have it.
I tried jump starting it from my wife's car, it did not seem to have the power to get it started. I had experienced that before. When I installed a brand new battery it cranked up and sounded as if it was not firing on all cylinders and crazy rough. It cut out. I started it three times and I managed to get in to reverse out of garage before it cut out again. Lumpy, loud, black sooty water from tail pipe.The Check engine light flashing and then The Restricted mode warning came on.
I changed the oil every 8K with Mobil 1 Extended Life 5 / 20 which is what I understood to be the same specs as The Castrol oil. It appears that should have been 0/20??
No ticking beforehand. Ran and idled Perfectly! I did have a check engine light that came on and off. It suggested that it may have been the MAF Sensor. Had it looked at and they said it was good. Light would go off for weeks and then pop back on for days. No loss of power. No gas mileage decreases. Accelerated as always. Had spark plugs changed $5K miles prior to this happening. .
The following 2 users liked this post by barnsie:
#46
I had to replace the engine in my 2014 XK this summer a month after buying it when it started overheating. They found metal shavings embedded in the oil filter and heard a 'knock' deep in engine somewhere. I never got a final explanation on what actually happened to it but thankfully it was still under warranty and they were able to find a used engine off another 2014 with fewer miles on it to replace it with!
The following 2 users liked this post by Locust0311:
George05 (11-13-2019),
Queen and Country (11-13-2019)
#47
#48
You shouldn't be insulted, as it was not my intent to insult you. I read that link 4 times on my Galaxy S8 and didn't see it. I see it now after clicking on Specifications and scrolling down to 0W-20. Thanks for pointing it out. If you had posted that screenshot in your initial post, you would have avoided this unpleasantness.
The good news is we now have a much lower cost major brand certified alternative available from several retailers. Just in time for me to change the oil on the 2 Rovers.
Stuart S (11-13-2019)
#49
As many others, I had similar symptoms, smoke, barely able to run, lumpy, etc, and like Cee Jay has reported all was related to fuel injectors. It's happened to me three times, and each time the fear is that the engine was toast, but in each case the car was running like a champ by the next day, Get it properly diagnosed.
The following 7 users liked this post by tberg:
barnsie (11-13-2019),
kj07xk (11-13-2019),
mosesbotbol (11-14-2019),
and 2 others liked this post.
#50
Overheating suggests cooling system so a new engine would not necessarily solve that problem. Last thing you want to do is replace another one.
#51
Honestly I don't think the dealer dug into the why, just that it was a goner. They did weld a crack in the downpipe so its possible that was causing the overheating and the metal shavings weren't what caused that specific problem and were just something else that was about to go. I also had to have the passenger side mirror replaced, several leaks fixed (including a cracked oil pan) and have some various fans and pulleys replaced. Thank goodness for warranties. I haven't had any issues in the months since the last of work was completed so fingers crossed that it all got taken care of.
#52
The following 2 users liked this post by JagRag:
CleverName (11-19-2019),
#53
#54
#55
#57
OK So not much clearer picture at the moment. The Report showed a litany of error codes which showed nothing. Everything had an error.
Probably due to Restricted mode and needed to be cleared.
The Comments are :"Timing chain likely skipped a tooth". The Oil filter they replaced, the old one has sparkly metal flakes very small.
So It needs a further look.
I wish I had taken it elsewhere to begin with. I need to find someone here in Atlanta that can look at it and give me a definitive answer on it.
My new F-Type has been a fun distraction in the meantime! More to come!
The following 6 users liked this post by U2vertigo1:
barnsie (11-22-2019),
Cee Jay (11-22-2019),
CleverName (11-22-2019),
Queen and Country (11-22-2019),
ralphwg (11-23-2019),
and 1 others liked this post.
#58
#59
New to the XKR (2010) world, but after reading and searching forums about the "approved" spec oil, I am still not clear on what is OK for my car. Especially since JLR published new standard SCN JLRP00119 changing the specification from STJLR.51.5122 to STJLR.03.5006 and in the case of my 2010 XKR that would mean from 5w-20 (my owners manual) to 0W-20 as I understand it. I know I could ask the dealership for the definitive answer but as mentioned, in scouring the forums, I've read where dealers have serviced Jags with various different brands and specs so not sure what that would solve. Bottom line, I'll comply with the spec or brand that's correct and safe for the car but of the two brands most talked about, Castrol and Mobil 1, on their website, when you type in your car they both say "nothing currently offered" or "nothing currently offered in the U.S. I know Jags are special but I've never seen so much discussion and consternation over what oil to use in a car. At this point, since I don't have a clear history of what "brand" was used I'm leaning toward just following the new standard for brand and weight and see where that goes.
#60
With only those papers on the table, we in the US would/should still be using 5W-20. Brands are to your own discretion unless your car is under warranty.
Errod88
09-14-2013 11:13 AM
BriteRed01XKR
07-17-2011 10:32 PM
