2010 shocks on a 2007
The BC coilovers certainly can be adjusted from hard to soft, manually with 30 steps plus custom spring rates, travel and height but still quite different from the Bilstein CATS. I remember on specific cobblestone roads, the CATS system did a brilliant job of smoothing the bumps. The BC coilovers don't switch between hard and soft automatically so it's something you either find a comfortable median or adjust based on road and driving style.
steve_k_xk (04-27-2023)
The following 2 users liked this post by Brewtech:
jahummer (04-26-2023),
Oh you also have .... unfortunately for myself whenever I want to firm up my suspension and lower ride height I have to do it the old fashion way a swap out my springs gets rather tiresome after a while !!!! .... plus the fact Ive got a front shock that has collapsed internally I'm thinking this is probably the best time to pull the trigger ....thanks guys
I think I posed the coil over vs OEM question before and you guys may have cautioned against it? IIRC a couple of mentions that the ride is much firmer and not Grand Tourer class? Am I wrong? I'm set with OEM but offer up the question for someone else who might read this and get the sense they are superior in comfort.
If you want comfort only and don’t care about performance then stick with OEM. Coilovers provide multiple adjustments, spring rate, ride height, rebound, compression, etc and really intended for those looking for improved performance, not comfort. In normal driving on good pavement surfaces, not much difference will be noticed but on corners, speed and rough uneven surfaces the difference will be notable though the BCs can be softened up quite a bit.
The following 2 users liked this post by jahummer:
Sean W (04-27-2023),
CleverName
07-15-2012 05:03 AM
