2010 XKR 35K, Code P2229 Limp Mode
Old 11-21-2020 | 07:38 PM
Shawn Robert's Avatar
Exclamation 2010 XKR 35K, Code P2229 Limp Mode
The car was running fine then s/owed down for a light and it went to hell. Ck Eng light and message about limited performance. Ran the codes and I have a Code P2229 , changed the plugs and coils, also sent the processor out to be evaluated. Was told it was bad and it was rebuilt by Module Experts in FL. Still the same. Any suggestions?
Old 11-21-2020 | 08:27 PM
Cee Jay's Avatar
A quick Google search says "Barometric Sensor Bad". Replace that, and all should be well. Course, it IS part of the ECU, so maybe a faulty flash? I don't know why the plugs and coils, unless that was for something else.
MarkyUK (11-24-2020)
Old 11-21-2020 | 09:15 PM
u102768's Avatar
If you are still getting a P2229 then it points to the ECM still having an issue.
Old 11-22-2020 | 10:35 PM
mhminnich's Avatar
Not being familiar with the current setup, is there a vacuum line running to the ecu like in the old days? Lack of expected vacuum at any given engine range can play havoc.
Old 11-23-2020 | 12:01 AM
Cee Jay's Avatar
Vacuum sensor, of course. Not a line. Don't ask me where anything is though, there are a LOT (most other people) who know stuff like this.
Old 11-23-2020 | 03:21 AM
JagV8's Avatar
All revealed in the workshop manual and the electrical guide - the latter shows every sensor used by the PCM (aka ECM). Free downloads
Old 12-08-2020 | 01:10 PM
There are no vacuum lines to the ECU. The ECU was sent out for repair and found to be good by EUC repair in Florida.
Was looking for something I'm missing before I take it to the dealership.
Old 12-08-2020 | 01:12 PM
I read the few posts that are out there and they say replace the ECU. I sent mine out to ECU repair I Florida and it was repaired and sent back and still the same issue. Before I take it to the dealership I was looking for any other information I could find.
Old 12-08-2020 | 01:22 PM
XJ8JR's Avatar
Barometric sensor would be the MAP sensor, wouldn't it? Replacing that would be a quick and cheap test before heading off to the dealership.
Old 12-08-2020 | 01:57 PM
gkubrak's Avatar
Sounds like you need a NEW ECM ... or a working used one.
As far as i remember, all they do is re-solder everything. Unless they replaced the failed internal component during the repair (which I doubt), the "repair" would do nothing.
Replacing the ECM requires re-programming, so you will need to take a trip to the dealer anyway.
Old 12-08-2020 | 02:00 PM
gkubrak's Avatar
No, thats a separate sensor. The manual (and post from u102768) mentions P2229 is related to an internal ECM failure.
Old 12-12-2020 | 03:17 PM
AlexJag's Avatar
Sponsor
If you have sdd jlr you can mate a used ECU to your car . I have done this numerous of times. I have SDD JLR setup I can loan if your in the USA
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
Old 12-13-2020 | 11:01 PM
guy's Avatar
guy
You’re braver than me... I wouldn’t let just anyone look at my ecu. And with that code, I can’t figure out why the plugs and coils were changed... as Cee Jay suggests... did you ‘tune’ your car...
Old 02-02-2021 | 03:21 PM
No vacuum hoses to the ecu
Old 02-02-2021 | 03:23 PM
There are no vacuum lines going to the ecu
Old 02-02-2021 | 03:24 PM
There are no vacuum lines going to the ecu or anywhere near it
Old 02-02-2021 | 03:25 PM
It is misfiring and I wanted to tune it up anyways.
Old 03-25-2021 | 08:38 PM
turns out the timing chain slipped and it has bent valves.
Old 03-25-2021 | 08:42 PM
AlexJag's Avatar
Sponsor
Crap...sorry to hear!
__________________
Old 04-02-2021 | 07:29 AM
guy's Avatar
guy
That does suck. But its a chain, not a belt. ‘slips’ just don’t ‘ happen’.
(Yes, I’ve rebuilt engines with a timing belt and overhead cam in my youth. It was the only way my father would give me a car)
But I’m afraid I don’t see the correlation between the code thrown and the valve situation. I have doubts.
Count your lucky stars though, that engine could have had enough loose metal in her that she’d sound like a change purse.
black_cat_02
01-21-2019 03:35 AM
Distraxi
12-20-2012 04:31 AM
Skid Mark
01-20-2011 06:58 PM
rpeppers
General Tech Help
10-12-2008 06:18 PM
Quick Reply: 2010 XKR 35K, Code P2229 Limp Mode
