2010+ XKR CATS Struts install on a 2010 5.0 XK w/ CATS
Received 1,974 Likes
IIRC, when I was looking for replacement front shocks for my 2007 XK, I looked at all the various part numbers used across all model years, and was surprised that the 2010-2011 XK and XKR used the same shock. The strut spring may have been different, as I didn’t check those, but found it odd that they used the same shock.
I hope this isn't construed as hijacking the thread, but perhaps asking for the same advice.
I have very limited mileage and seat time (<2000 miles total) in my recently acquired 2014 XK Touring coupe with 39K miles, and am trying to figure out exactly the ‘floaty’ feel of the ride. The steering, handling, and ride over cracks, potholes or rough road seems absolutely fine. No extra noises, no shudders or vibrations. Rock solid. But on highway that is less than totally smooth, I seem to be bouncing (or floating) down the highway, to a point that I almost get nauseous at times. I don’t experience this in any of my current vehicles (2014 C-class, 2002 Passat with recently installed Bilstein B6 shocks, and 2012 Lincoln MKZ with original suspension). I can’t decide if there is something wrong or this is the intended feel. I’d like to change it but don’t know how. So I read with interest the notion of changing the springs and hope that advice could apply to my car. Anyone else able to comment? Thanks
Edit: I wondered if there was a problem with the electronic shocks but no error codes.
Chris as has been said earlier I think all XK's have the same set-up, except on performance models, so fr instance my XK Dynamic has a bilstein shocks and shorter springs which are rather...erm...hard. They are IIRC the same as fitted to the XKR-S mentioned by Auzzie Steve.
So some questions:
1) Are you running 20" rims?
2) Tracking/Alignment last done?
3) Tyre band and pressures?
Wouldn't have thought that you'd have any bushes perished on a 2014 yet, so can rule that one out
So some questions:
Is this bouncy ride in normal mode or dynamic mode? I have found that Dynamic mode and highways/Autobahns don't mix well. In normal mode all is smooth enough and the suspension seems quite refined. In dynamic there is a more pronounced up-down bouncing over road level changes, but it is not floaty, rather too stiff. Dynamic is for twisty roads and the limited damper range is not required on relatively straight roads.
Thanks for the input; I appreciate your help. What I wonder is whether the ride is actually stiff, and the bounce I am describing is just a stiffer ride than I am used to. Almost feel like if I put a couple of cement blocks in the back it would 'fix' it. This is all in normal, not dynamic mode. Tires are 19", inflated properly, and no wear. Haven't checked the alignment but it tracks very straight. Compared to Mrs.'s Merc, I really like the seats in the XK - my 2 long drives were very easy on my creaky back - but the ride is, well, different.
Maybe I need to get a suspension tuner to do a ride along.
Maybe I'm just nuts.
When the 5.0 engines were introduced the suspension was also stiffened and the difference between the XK and the XKR was also reduced. Some journalists commented at the time whether Jaguar had gone too far for their usual customers.
You said "The steering, handling, and ride over cracks, potholes or rough road seems absolutely fine." This is a fair sign that the car is not majorly misaligned. If you are getting constant deflections over bumps, check the tires for wear on the edges - tells you quite a lot about how good the alignment is. Also as you sweep left and right across the steering center point, the change should be linear. If it seems sticky, again, alignment could be out (but might still be withing the "acceptable" range).
hawaiianjag
08-30-2022 10:16 AM
vettegood
12-18-2014 09:39 PM
abonano
12-22-2013 04:35 PM
joenglishgirl
06-23-2013 05:07 AM
ehaglund
10-18-2012 11:29 AM
