2010 XKR front end noise and shake issue
So my 2010 XKR recently developed a pretty significant front end noise (classic whop whop whop whop) and front end/steering wheel shake. I initially thought my front passenger rim was bent, causing these issues, which I’ve experienced before with a back rim and this seemed like it was doing the same thing. I was in the market for new wheels, so I replaced all four rims/tires with a set of aftermarket TSW’s. Same offset, only the rear rims are a little wider. After having all 4 tires balanced and mounted, the noise and shake is still there. It’s worse and lower rpms, while breaking, and while going around curves. You can feel it through the entire front end, tho it seems to be coming from the front passenger side mostly. And it’s loud enough to be extremely obnoxious while driving unless the radio is up. It’s a constant noise and shake, and I’m looking for ideas to get this taken care of. I’m almost nervous to drive it in fear it may do more damage, but being my only transportation at the time, I kind of have to. So any help getting this figured out is greatly appreciated. I have not had it aligned in about 1.5yrs, it jus seems like more noise and vibration then that would cause, but I guess it could be anything at this point. Thanks
I haven’t taken it anywhere yet, and yes I was going to see if I could fix it myself. I did find a ball joint nut backed about halfway off, tightened it all the way back down, but still no change
If the top picture is the upper A frame ball joint you are lucky so far. It is shot and will either break or separate from the socket. I suspect that what is causing the noise and the vibration may have caused the lower nut to come loose. Don't drive it until it is fixed. Check all of the joints and replace suspect ones.
The following 2 users liked this post by jagtoes:
Queen and Country (08-04-2019),
Sean W (08-04-2019)
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/750x1334/73ca2b21_df71_4e8e_9ba2_a40c8e422b1e_d3bab50303b0b98e431c39dee8b5c7cd5e24d0fb.jpeg)
https://www.ebay.com/itm/2PCS-Front-...S/272301201155
Sean W (08-05-2019)
Queen and Country (08-05-2019)
Fairly easy. There isn't really a good place to put leverage on the upper joint though. With the wheel on jack the car up and put it on jack stands. Grab the tire at its axis (12 and 6 o'clock) and rock it. There should be no play. If you hear noise/ play from the upper, you have a bad ball joint. Looking at yours, if it's me, I'm replacing it.
On the lower you can remove the wheel and place a pry bar or screwdriver between the joint and the knuckle and look for play.
Bkny85
04-01-2014 02:03 PM
