2010 XKR Gets 5.0 with 500+hp
I'm sure many of you have seen this already but was I bummed when I read it! I just spent loads of $$$ to get my XKR close to 500hp, and now you can just buy one already to go! Doesn't seem fair, now I want a new one
http://www.topspeed.com/cars/jaguar/...r-ar69099.html
Seems like their 0-60 times aren't as good as they should be, but then again most of the 07-09 run faster than the 4.9 Jaguar Quotes.
Here is another great link about the car with the "official" press release. Damn it's tempting!
http://www.autoblog.com/2009/01/10/d...tty-has-claws/
Nice pics!!
Very different placement of foglight in front(those are lights, right?) Actually just "slats" ? got rid of fog all together..huh
The exhaust looks slightly larger also?
And of course switched to the FX "rising gear dial".......gives it the "Ahhh" factor when showing it off to friends!!!!
S
S
The verticle slats behind the front wheels are body colored now on the R, not silver...the all new engine is definately a big plus. Im guessing the2010 xkr will cost $5k more than an2009 just for this improvement alone. 500 hp...nice!...Not really excited about the front bumper change & wheels w/ jaguar-supercharged embossed in it. Rear LED lights are an improvement for safety & look good too.
Just saw a powerpoint on the 5.0. I thought it said the injectors and electronics were going to be Denso but I could be mistaken. Direct injection with dual mechanical fuel pumps driven from crankshaft with chains for 2000+psi(150bar) fuel pressure. 4 VVTs and variably selective camshaft profile with an additional 5mm lift for high rpm operation and power.
ORIGINAL: GHOSTRIDERXKR08
Finally....LED Taillights! I've been looking for these....LOL. Hopefully an easy plug and play retrofit to the pre '10.
Does anyone happen to know if they will be 'retro-fittable'?
I noticed that the Aston Martin boys over on 6Speedonline are all up in a lather about the new XKR. They want more power!
On another note, according to my local Jaguar dealer, the F-Type is a definite go. Most likely a turbo V6 to keep weight down. Also under serious consideration is a 4 door XK8-XKR similar in concept to the Aston Martin Rapide. Not sure if this will replace the XJ series or will be an addition to the XK line.
Honeyman, can you post some pictures of your cars up please. Im interested to see how the pre 08 cars, especially luxury models look with cremona wheels on them.
My next Jaguar will be an XJ most likely and ill end up putting the 20" portfolio/callisto wheels either polished or chromed
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
FS[MidWest]: 2010 XKR convertible
JaguarJoseph
09-16-2015 11:19 AM
