2010 XKR - Hard Reset ECU (verification?)
Hello all,
2010 XKR vert. I tried the hard "resetting" of the ECU to delete prior owner's driving pattern. I disconnected the battery (both pos and neg) for about 25-30 minutes. When I started the car, a message popped up that I had to push the brake and the electronic brake. I reset the windows. How do I know if this reset the ECU? The radio stations remained as before. All of the vehicle settings were the same as before. I did notice that it takes longer for the convertible rear quarter windows to go up.....and the front windows don't go up now as the last step of the top being put up. Please advise.
Yes, a Hard Reset resets all the volatile memory. That includes the ECU. However, maybe not the TCU. Did you reset the windows correctly? They will auto-up and auto-down if done correctly. The E-Brake sometimes needs a reset, sometimes not.
Radio, seat memory and dash stuff remains intact.
UKWyldcat (10-03-2020)
When you did your 'hard reset' did you touch and hold the positive and negative terminals together...as you made no mention of that? As it's such a palava to get to our battery I bought one of these and can confirm it makes a real difference to gear changes
https://www.diesel-performance.co.uk...ox-flash-tool/
It made a real difference to the transmission of my car, and, should I wish to reset the TCU again, I can in about 5 minutes![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Also remember that, whilst Jaguar state their transmission is 'sealed for life' ZF who make it recommend a fluid change (IIRC) at 50k miles and then every 30k miles beyond that, mine is on 54k and is going to have mine done at a ZF master centre next month.to have this done, which includes all fluid in the TC
Best of luck
Best of luck
George05 (10-04-2020)
James Finney
01-04-2020 09:20 AM
