2010 XKR Power Steering Top Off?
When I am at a stop and I make a left or right hand turn, I get some vibration in the steering wheel. I am 95% sure that this has nothing to do wit the wheels or tires. I then looked at my power steering reservoir and the top has three notches on it. The manual says it should be between notches two and three. Mine comes up to the top of notch one. So, do I top it off? Also there seems to be a few threads on what type of power steering fluid to use. I am in the US, so certain brands may not be readily available.
Thoughts?
Thoughts?
ralphwg (10-24-2020)
I would use the Pentosin 202 (or 11S) which are both synthetics. Pentosin says not to mix with earlier 7 fluid as not compatible.
Received 1,179 Likes
In my particular case, steering wheel “feel” was significantly improved by performing a flush. I went the extra step and replaced the reservoir.
Absolutely stick to the specs for the replacement fluid.
You may be surprised to see just how bad the state of the current fluid is when compared to fresh. I was.
Sean W (10-24-2020)
wouldbeowner
09-09-2019 11:05 AM
sunchip
01-28-2015 08:21 AM
