2010 XKR Supercharger Torsion Isolator
Old 02-24-2015, 03:41 PM
Old-Bugga's Avatar
Default 2010 XKR Supercharger Torsion Isolator
One for you to check. Can't imagine I am the first or will be the last to have this occur.
https://vimeo.com/120490870
2010 Jaguar XKR 5.0 with 77,000 on the clock. Perfect service history.
Looks to be a known issue with these Superchargers. Jaguar issued a technical bulletin regarding it and we did the repair under warranty. The torsion isolators job is to cut down on chatter at low revs. Problem, is the hardened spring, starts to eat the pulley shaft. End result is , you end up with a sound like marbles being thrown around the engine.
Nose section of the supercharger was replaced as part of the repair kit.
Although not Jaguar I am pretty positive this is the same unit fitted to a different car.
This link does a better job of explaining this than I can.
hooniverse.com/2012/08/01/the-rattling-sounds-of-the-cadillac-cts-v-supercharger/
Jaguar Supercharger Torsion Isolator Issue
The following 5 users liked this post by Old-Bugga:
boiler (03-04-2015), DGL (02-24-2015), Gregstan (08-04-2017), Neville Hobbs (07-30-2017), Reaxions (08-30-2022)
Old 02-24-2015, 08:20 PM
DGL's Avatar
DGL
DGL is offline
Interesting. Anyone else experience a similar problem.
Old 02-27-2015, 08:36 PM
boiler's Avatar
My 2011 XFR sounds like it has a bucket of marbles rattling around near the front of the supercharger.
Do you have the technical bulletin number so i can pass that along to my service manager.
Old 02-27-2015, 10:38 PM
Old-Bugga's Avatar
Yes, here you go. Anybody able to access this and post a copy?
JTB00349v2
boiler (02-28-2015)
Old 02-28-2015, 01:50 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
Here you go.
The following 3 users liked this post by u102768:
boiler (02-28-2015), Gregstan (08-04-2017), Ngarara (02-28-2015)
Old 02-28-2015, 02:05 PM
boiler's Avatar
Thanks guys
My car is already in the shop for another issue I will be sending this their way on Monday.
Old 02-28-2015, 11:38 PM
Old-Bugga's Avatar
If you are doing this job, it's an ideal opportunity to change the upper pulley.
http://www.powerhouseautomotive.co.u...er-pulleys.php
Old 03-01-2015, 07:23 AM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
If the pulley change gives an extra 25-40HP is this the reason for the 40HP difference between the 5.0 XKR to XKR-S. Would I expect to see a smaller pulley on the S or is there another way to get the additional HP from the stock R. Also if you do this change on an S what is the projected HP gain over the 550.
Old 03-01-2015, 07:30 AM
Received 4,458 Likes on 2,427 Posts
No, the difference between the XKR and XKR-S is the tune, the engine is the same. The pulley is the same on all engine variants.
Old 03-01-2015, 07:52 AM
JgaXkr's Avatar
This is a common issue with the Range Rovers using the 5.0 supercharged engine.
DGL (03-01-2015)
Old 03-01-2015, 02:50 PM
Ngarara's Avatar
Received 1,126 Likes on 797 Posts
Some of it comes from the Performance Active Exhaust, but most is the tune.
Old 03-04-2015, 11:54 AM
boiler's Avatar
The shop checked my supercharger and ended up replacing the torsion isolator. Apparently the service bulletin has been updated and I will be posting the new # when I get the paper work.
Thanks again for bringing up this issue.
Old 03-04-2015, 04:57 PM
boiler's Avatar
Originally Posted by u102768
Here you go.
Here is the service bulletin they used JTB00349NAS1
What are the differences?
Old 03-04-2015, 05:37 PM
u102768's Avatar
I think the NAS1 means it is version 1 of the TSB and is one published for the USA dealers. The one I posted is a UK one and is on version 2.
Judging by the dates they were published on Jaguar's website they probably have the same content because they were published within a couple of weeks of each other.
Old 03-04-2015, 05:40 PM
Ngarara's Avatar
NAS = North American Specification
Old 03-06-2015, 05:09 PM
Lothar52's Avatar
Just today I opened up my 2012 XKR hood with 19,500 miles on her to start her up and see how the battery charger is keeping the car and see if there is any tire pressure lights on.
I heard marbles in the engine!!! Mind you not nearly as bad as the marbles you hear in the video of the 2010....but they WERE THERE.
Too check and make sure I was not hearing things I also went ahead and started up my 2013 XKR-S with only 2012 miles on her. NO Marbles at all.
Sounds like my supercharger in the 2012 needs some work!!
Question: is it just an annoying sound that occurs with these superchargers over time and needs replacement or "fixing" or is the engine supercharger going to fail somehow???
Loth
Old 03-06-2015, 05:43 PM
Lothar52's Avatar
Tried to record what I was hearing but the sound clip sounds fine... I dont know what to make of it. I guess when spring comes and I have 9 more months of factory warranty I will demand they investigate the supercharger for the TSB and print it out.
Loth
Old 03-06-2015, 06:20 PM
DGL's Avatar
DGL
DGL is offline
Loth
The sooner you take it for repair the better. Let us know what happens. We always stay together on this forum. One for all and all for one.
Lothar52 (03-06-2015)
Old 03-06-2015, 08:34 PM
Lothar52's Avatar
Brothers from other mothers baby!! You know it!!
Old 03-08-2015, 03:10 AM
Seems to be very common indeed, stumbled across this guy selling "core" superchargers on ebay. Jaguar Range Rover Supercarger Core | eBay
Presumably these are units with bad couplers... "more than 10 available"
Quick Reply: 2010 XKR Supercharger Torsion Isolator
