2011 XKR 16 way seat retrofit in a 2007 XK with 10 way seat adjustment
I don't recall anyone who has done exactly what you want to do. I doubt that it's a straight away, easy swap since there are differences between those seats. Sensors in the seat communicate with the airbags, programming may be needed, the seat controls, electrical connectors, and modules may be different, etc.
Anything can be done with enough money. But does it make sense to do it?
Yes can be done
Either hard wired in or new connector harnesses made up and SDD is a must to reprogram .
Make sure the seats come with the 16 way modules as most wreckers remove them and you'll also need the 16way adjustment that sit in the door trim
Its definitely not a easy modification at all nevertheless have a look at thread below
https://www.jaguarforums.com/forum/xk-xkr-x150-33/xkr-s-seats-195760/page3/
I can include the wiring connectors so you can re-pin them if needed.
