2011 XKR Battery Problem
Wit the top up open the trunk. Remove the convert top safety cover. There are 4 black plastic screws that hold in the back carpeted panel. Remove the 4 screws and remove the panel. The battery is right in front of you. I believe it is also shown in the OM. Also do not attach the carger neg. terminal to the battery neg terminal. There is a ground stud located in the spare tire hole. Also if you remove the plastic grill on the left side just inside the trunk there ir a positive terminal you can put the charger on.
The following 2 users liked this post by jagtoes:
Aprilia2012 (06-28-2018),
Mark JC (11-07-2016)
