2011 XKR A/C condenser replacement
Radiator does not need to be removed, but you will need some clever universal sockets to get to the bolts.
I suggest changing your drier desiccant if you are changing the ac compressor, accessible under the condenser
after removing the lower front splash guard.
Ebay sells authentic OEM compressors for around 400.
Note I have a 5.0 XK not XKR, but I believe the process is the same down there.
